Unfortunately I do not use the HS-Monitor, so testing is not possible.
But in order to check whether the actuator replies to a READ-Telegram correctly, just send a value-read telegram on the appropiate Groupaddress via the ETS or via the "Befehl" "Abfragen" via the HS.
If it works, you should receive the actual state of that channel or you will see the answer in the HS-EIB-Monitor accessible via hslist if activated at "Systemlisten" in the Experte.
