KNX and Google Home
    KNX and Google Home
    Hi.
    I bought some google home devices to start voice controlling my KNX devices. I currently use eventghost (on a dedicated server) and Gira Home Server to control my house.
    I've seen some hardware devices to bridge the 2 systems together but I was looking for a cheaper, software only option.
    What are you using for that? Can someone point me in the right direction?
    Thanks.
    Regards,
    Mike
    1) https://github.com/nfarina/homebridge
    2) https://github.com/snowdd1/homebridge-knx
    3) https://github.com/oznu/homebridge-gsh
      derPaul,
      Thank you!
      I will start playing with those
        you are welcome ... feel free to ask any questions :-)
          Did you install it all manually on a system or in a VM or did you use a (almost ready) Docker which can do: KNX + Google + Homebridge ?
            Hey Roel, i let this run into Docker on my Synology.
            This Container : https://hub.docker.com/r/oznu/homebridge
              derPaul,
              Perhaps you can help me a bit further...
              I am having trouble running KNXD and Homebridge on the same docker server. I seems that homebridge can't see knxd when it is running on another container.
              Is there any way I can run both containers on the same machine?
              Thanks.
                whats your network configuration of your container? host or bridge?
                in my setup both container running on the same host, and the network ist configured as host network
                Zuletzt geändert von derPaul; 13.01.2020, 16:39.
                  Thanks!
                  I figured out what I was doing wrong: I was running knxd without the -i parameter. It was enough for Homebridge to complain about missing knxd
                  Thanks again.
