Wakeup lamp - Logic block
    HS/FS Wakeup lamp - Logic block
    Hello,
    I would like to use some luminaries as a wake up alarm, by slowly dimming them up from 0-100% during about 20 minutes.
    I tried making my own logic in the logic editor but I realized it will get pretty big and complex with all the nodes required and it might not be that reliable.
    Anyone here have made a similar logic that you would like to share?
    This is on a HS, but I also have a L1 present if you have something made for L1.
    I use something similar to step down a fan over a specified amount of time (using the HS). It is in essence only a single line of logic which has an input box, a telegram generator, and an output box. When 'ON', it steps (down, in my case) the %-value of the fan using the 'step' command in the outbox. If you were to set the step size to '1', then your telegram generator has to trigger every 12 seconds.
    Add a condition that when it reaches the end then it stops the telegram generator.
      sx3 Have a look here: http://service.knx-user-forum.de/?co...nload&id=19856
        In the past i made my own because i needed one that would accept an overwrite when the light were turned on manually. Its pretty easy to do that with HSL 2.0.
