Denon POA-3012CI logic modules
    HS/FS Denon POA-3012CI logic modules
    I've made some logic modules to control a Denon Poa-3012Ci for multiroom audio.
    The Denon is connected to a Moxa nport via RS232. I have feedback as well for the 6 zones. Power, Volume and Source.
    The only problem I have is the initialisation. I need to send a few commands to the Denon but with a 200ms delay. I know how to sent 1 command when the module gets initialised.
    Somebody has any ideas?
    The commands I need to sent are for example, PW00?\r folowed by ST02?\r etc.
    If somebody is interested in the modules I can email them. Unfortunatly I'm not registered with DACOM so I don't have an assigned series of numbers for modules.
    Next on my list will be the Denon AVC-A1HDA. The POA has very few commands compared with the AVC. So this is my debut into logic modules.
    Greets
    Marco
    Hi Marco,
    you can also provide your solution at Download area here in the Forum. Every User can do so ;-)
    And for the Logic Module ID ? I think there will be also a solution possible.
    BR
    Tbi
      Before I release the modules I want the initialisation to be done as well. So any help before I release is welcome.
      The problem is that I need to sent about 5 command during initialisation to get the parameters from the Denon. I can do it through a sequence in the HS but I would like to integrate it into the logic module.
      There need to be a minimum delay between the commands of 200ms. The first command is easy. Therefore I use the EI. It then sends the PW00?\r command. I then need to sent the second command ST02?\r but with a minimum 200ms delay. Any idea?
      Can I use EI and OC[1] as formula?
      greets
      Marco
        a timer in logic
        Hi marco,
        see here is a Timer used:
        http://www.dacom-homeautomation.de/c...ndenImpuls.hsl
        and here more infos:
        DaCom - Database Computing GmbH
        hope this helps
        Tbi
          I'm still struggling to get the initialisation done!
          During the init from the module I have to sent a few commands (ascii) to get the feedback from the amp. It sends the first command for the master power but then I like to request the status of each individual zone.
          This is what I've done.
          #Query
          5012|0|"EI"|""PW00?""|"1"|1|1|0|0
          5012|0|"EI and OC[1]"|""ST02?""|"1"|1|2|0|0
          5012|0|"EI and OC[2]"|""ST04?""|"1"|1|3|0|0
          5012|0|"EI and OC[3]"|""ST06?""|"1"|1|4|0|0
          5012|0|"EI and OC[4]"|""ST08?""|"1"|1|5|0|0
          5012|0|"EI and OC[5]"|""ST10?""|"1"|1|6|0|0
          5012|0|"EI and OC[6]"|""ST12?""|""|1|0|0|0
          Obviously this doesn't work.
          Can somebody offer any help?
          The commands have to be separated by 200ms.
          Marco
