Hallo
Ja, Habe ich im Router so eingestellt.
Gruß NetFritz
@makki
die :85 ist aber absichtlich so eingestellt oder?
Gruß NetFritz
!/usr/bin/perl -w
use strict;
use warnings;
use IO::Socket::INET;
use JSON;
my $debug=0;
my $webboxIP = "192.168.2.251:85";
my %rpc = ();
&configure_requests;
&cls;
my $data = &get_data_from_sunny_webbox($webboxIP,$rpc{"get_devices"});
print "RPC_GET_DEVICES : \n";
print "----------------- \n";
print $data."\n\n\n";
my $js_hash_ref = decode_json $data ; # decode JSON Data , result is a Hash-reference
my $tab = -1; # preset number of tabs to format printout
&print_hash($js_hash_ref);
&pause(1);
$data = &get_data_from_sunny_webbox($webboxIP,$rpc{"get_plant_overview"});
print "RPC_GET_PLANT_OVERVIEW : \n";
print "------------------------ \n";
sub print_hash {
my $hash_ref = shift; # reference to a hash
my %h = %$hash_ref; # dereference
$tab++;
my $t = "\t"x$tab;
foreach my $k (sort keys %h) {
print "$t$k: ";
if (ref($h{$k}) eq "HASH") { # if element is a hash then print it ...
print "\n";
&print_hash($h{$k});
next;
if (ref($h{$k}) eq "ARRAY") { # if element is an array then print array
print "\n";
&print_array($h{$k});
next;
print "$h{$k}\n";
if ($debug) {&pause}
$tab--;
sub print_array {
my $arr_ref = shift; # reference to an array
my @arr = @$arr_ref; # dereference
$tab++;
my $t = "\t"x$tab;
foreach (sort @arr) {
print $t."\t";
if (ref($_) eq "HASH") { # if element is a hash then print it ...
print "\n";
&print_hash($_);
next;
if (ref($_) eq "ARRAY") { # if element is an array then print array
print "\n";
&print_array($_);
next;
print $_."\n";
$tab--;
sub get_data_from_sunny_webbox {
my $ip = shift;
my $request = shift;
my $response;
my $received;
my $RecvSocket = new IO::Socket::INET->new(LocalPort=>34268,Proto=>'udp');
my $SendSocket = new IO::Socket::INET->new(PeerPort=>34268,Proto=>'udp',PeerAddr=>"$ip");
my $cs = $SendSocket->send($request);
if ( ! defined $cs) { return "Send-Error";}
$response = $RecvSocket->recv($received,1024);
$received =~ s/\0//go;
undef $RecvSocket;
undef $SendSocket;
return $received;
sub configure_requests {
my $r = "get_devices";
my $obj = '{ "version":"1.0", "proc":"GetDevices", "id":"1", "format":"JSON" }';
$obj = &add_null_chars($obj);
$rpc{$r} = $obj;
$r = "get_plant_overview";
$obj = '{"version":"1.0", "proc":"GetPlantOverview", "id":"1", "format":"JSON" }';
$rpc{$r} = $obj;
# add more requests here ...
sub add_null_chars {
my $s = shift;
$s =~ s/\s//go;
$s =~ s/(.)/$1\0/go;
return $s;
sub remove_null_chars {
my $s = shift;
$s =~ s/\0//go;
return $s;
sub cls {
my $os = $^O; # get Operating System
if (index(lc($os),"win") > -1) {
system("cls"); # Windows then clear screen (batch command)
} else {
system("clear"); # Linux/Unix/Solars clear screen (bash command)
sub pause {
my $pr = shift;
if ($pr) {print "\n\n\npress <return> to continue ...\n"}
my $p = <stdin>
[URL]http://IP_der-Webbox/rpc?RPC=[/URL]{"version":"1.0","proc":"GetDevices","id":"1","format":"JSON"}}
[URL]http://IP_der-Webbox/rpc?RPC=[/URL]{"version":"1.0","proc":"GetProcessDataChannels","id":"1","format":"JSON","params":{"device":"0083:7e5cb61d"}}
"version": "1.0",
"proc": "GetProcessData",
"id": "1",
"format": "JSON",
"params":
"devices":
"key": "004e:7d30b9bc",
"channels": null
"version": "1.0",
"proc": "GetPlantOverview",
"id": "1",
"format": "JSON"
# return;
# holt über HTTP-RPC die Daten von der SMA-Webbox
# es wird GetProcessData und GetPlantOverview abgefragt
# by NetFritz 5.2012
use HTML::Entities;
use LWP::UserAgent;
use JSON::XS;
use DBI;
my $stkd;
# in $iso steht Datum-Zeit = 'Y-m-d H:M:S'
my @dta = localtime(time);
my $iso=($dta[5]+1900)."-";
$iso.=sprintf('%02d-',$dta[4]+1);
$iso.=sprintf('%02d ',$dta[3]);
$iso.=sprintf('%02d:',$dta[2]);
$iso.=sprintf('%02d:',$dta[1]);
$iso.=sprintf('%02d',$dta[0]);
# ======= Anfang Konfig =======
my $url = "http://192.168.2.7:85"; # IP der Webbox
my $key = "xxxx:xxxxxxxx"; # Key des WR muss vorher ermittelt werden
my $leistung_ga = "5/0/1";
my $leistung_pro_kw_ga = "5/0/2";
my $tagesertrag_ga = "5/0/3";
my $gesammtertrag_ga = "5/0/4";
my $zustand_ga = "5/0/5";
my $meldung_ga = "5/0/6";
my $DC_Strom_Eingang_ga = "5/0/7";
my $DC_Spannung_Eingang_ga = "5/0/8";
my $Netzstrom_ga = "5/0/9";
my $Leistung_Haushalt_ga = "5/0/15";
# ======= Ende Konfig =========
# Eigenen Aufruf-Zyklus auf 60 Sekunden setzen
# der Aufrufzyklus ist unabhängig von der Taktzeit und muss kürzer sein!
$plugin_info{$plugname.'_cycle'} = 60;
my $res;
my $ref;
# ===== Abfragestring GetProcessData =====
my $callobj = '/rpc?RPC={
"version": "1.0",
"id": "1",
"format": "JSON",
"params":
"devices":
"key": "'. $key .'",
"channels": null
# ==== Abfragestring GetPlantOverview =====
my $callobj1 = '/rpc?RPC={
"version": "1.0",
"id": "1",
"format": "JSON"
# ====== Abfrage GetProcessData ======
$res = $url.$callobj;
$ref = rpcs($res);
my $Ipv = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[0]->{'value'}; # DC Strom Eingang
my $Upv = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[1]->{'value'}; # DC Spannung Eingang
my $Fac = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[5]->{'value'}; # NetzFrequenz
my $Iac = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[6]->{'value'}; # Netzstrom
my $Pac = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[7]->{'value'}; # Leistung
my $Riso = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[8]->{'value'}; # Isolationswiderstand
my $hon = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[10]->{'value'}; # Einspeisezeit
my $hTotal = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[11]->{'value'}; # Betriebszeit
my $ETotal = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[12]->{'value'}; # Gesammtertrag
my $NetzEin = $ref->{'result'}->{'devices'}->[0]->{'channels'}->[13]->{'value'}; # Netz-Ein
# return $Ipv . "=" . $Upv . "=" . $Fac . "=" . $Iac . "=" . $Pac . "=" . $Riso . "=" . $hon . "=" . $hTotal . "=" . $ETotal . "=" . $NetzEin;
# ===== Abfrage GetPlantOverview =====
$res = $url.$callobj1;
$ref = rpcs($res);
my $GriPwr = $ref->{'result'}->{'overview'}->[0]->{'value'}; # Leistung
my $GriEgyTdy = $ref->{'result'}->{'overview'}->[1]->{'value'}; # Tagesertrag
my $GriEgyTot = $ref->{'result'}->{'overview'}->[2]->{'value'}; # Gesamtertrag
my $OpStt = $ref->{'result'}->{'overview'}->[3]->{'value'}; # Zustand
my $Msg = $ref->{'result'}->{'overview'}->[4]->{'value'}; # Meldung
if ($Msg == ""){
$Msg = "iO";
knx_write("5/0/24",0,1); # PV Stoerung false
}else{
knx_write("5/0/24",1,1); # PV Stoerung true
$plugin_info{'email.pl.Stoerung'} = $Msg." ".$OpStt;
knx_write($gesammtertrag_ga,$GriEgyTot,9);
# return $GriPwr . "=" . $GriEgyTdy ."=". $GriEgyTot ."=". $OpStt ."=". $Msg ;
# return $GriPwr;
# system("/usr/bin/nohup ./var/www/myhouse/cron/sml_zaehler.pl"); # Zaehler-Script aufrufen
# auf den KNX-Bus schreiben
# my $Tag_CO2_vermeidung = $GriEgyTdy*700; # 700g/kWh
# Werte auf den BUS schreiben
knx_write($leistung_ga,$GriPwr,9);
knx_write($leistung_pro_kw_ga,$GriPwr/4.05,9);
knx_write($tagesertrag_ga,$GriEgyTdy,9);
# knx_write($gesammtertrag_ga,$GriEgyTot,9);
knx_write($zustand_ga,$OpStt,16);
knx_write($DC_Strom_Eingang_ga,$Ipv,9);
knx_write($DC_Spannung_Eingang_ga,$Upv,9);
knx_write($Netzstrom_ga,$Iac,9);
knx_write($meldung_ga,$Msg,16);
my $leistung_pv = knx_read("5/0/1",0,9);
my $Leistung_Zaehler = knx_read("5/0/12",0,9);
my $leistg_haush = $leistung_pv-$Leistung_Zaehler; # Leistung Haushalt
knx_write($Leistung_Haushalt_ga,$leistg_haush,9);
my $eigenverbrausquote = eval {sprintf ("%.1f", $leistg_haush/($leistung_pv/100))};
if($eigenverbrausquote > 1000)
$eigenverbrausquote = 1000;
# my $eigenverbrauch = $leistg_haush/($leistung_pv/100);
my $eigenverbrauch = eval { sprintf ("%.1f", $leistg_haush/($leistung_pv/100))};
if ($eigenverbrauch <= 0)
$eigenverbrauch = 0;
elsif($eigenverbrauch > 100)
$eigenverbrauch = 100;
knx_write("5/0/16",$eigenverbrauch,9);
update_rrd("Eigenverbrauch","",$eigenverbrauch*10);
# 70%Regelung
my $siebzig = 2835; # 70% von 4050Wp
if ($Leistung_Zaehler > $siebzig){
update_rrd("pv_70","",$Leistung_Zaehler - $siebzig);
}else{
update_rrd("pv_70","","0");
# Wert in RRD schreiben
update_rrd("pv_leistung","",$GriPwr);
update_rrd("pv_leistung_kW","",$Pac/1000);
update_rrd("pv_std","",$Pac/1000); # 1 Wert pro Std.
update_rrd("pv_10min","",$Pac/1000); # 1 Wert pro 10min.
update_rrd("pv_tagesertrag","",$GriEgyTdy);
update_rrd("pv_DC_Strom_Eingang","",$Ipv*100);
#update_rrd("pv_DC_Spannung_Eingang","",$Upv);
update_rrd("Leistung_Haushalt","",$leistg_haush);
update_rrd("pv_Eigenverbrausquote","",$eigenverbrausquote);
# schreibt in DB
# DB oeffnen
my $dbargs = {AutoCommit => 0, PrintError => 1};
my $dbh = DBI->connect("dbi:SQLite2:dbname=/var/www/myhouse/sq_lite/myhouse.sqlite", "", "", $dbargs);
#if ($dbh->err()) { die "$DBI::errstr\n"; }
# $dbh->do("UPDATE myhouse SET date_zeit='".$iso."', wert='".$GriEgyTot."' WHERE adr='5/0/4'");
# $dbh->commit; # Änderungen auf die Datenbank einfügen
# $dbh->disconnect(); # DB schliessen
# ===== Sub holt die Werte von der Webbox =====
sub rpcs{
my $res = shift;
my $brs = LWP::UserAgent->new;
$brs->timeout(5);
my $req = HTTP::Request->new(GET => $res);
my $resp = $brs->request($req);
if($resp->is_success()) {
# print "Erfolg !";
}else {
return "Keine Antwort !";
my $content = $resp->content;
my %js_hash_ref = %{decode_json $content};
my $ref=\%js_hash_ref;
return($ref);
#return($stkd . $OpStt. "=" . $Msg);
return();
