Dear KNX Forum members,
First of all I like to make my apologies that am asking you help in English. Secondly if the question I am asking is already being discussed sorry again, I searched for it for a long time but maybe because my German is not so good, I overlooked the answer.
Here is my question.
I would like to get 1 from on the KNX bus if an external status led from my external motor (used for a swimming pool) switched to on (this happens if the motor worked for more than 15 hours) this LED light is built into the control panel of the motor (I have access to the PCB) and if possible I would like to leave the LED in place and working. Is there a way I can get signal from the 2 contact from this led, connect then to a KNX input actor? (or whatever is needed) to generate the status on the bus?
Thanks for your help...
Wouter
Wouter
It works without any problems for "old-fashion" Ferraris-powermeter and I used it successfully to count LED-Signals from an electronic-meter.
