- √ - GLE: Blattgröße
    HS/FS - √ - GLE: Blattgröße
    I'm designing an alarm function within the GLE.
    It's not complicated but there are many elements and the worksheet is almost full.
    The size is already at "Sehr groß"
    Is there any way to extend the sheet size ? or any trick to work around ? (besides re-writing everything).
    You may use connectors.
    Create an Output Box and right-klick. ther eyou can "add connector" for each signal that sis required at the extension. Then you create a new sheet to extend the existing one and add the so created connectors to an input box.
    Cheers,
    gaston
      Why don´t you put some elements onto a new worksheet, as long as the sheet itself has nothing to do with the logic. You may use the connectors.
      Gruss aus Radevormwald
      Michel
        Create an Output Box and right-klick. there you can "add connector" for each signal that sis required at the extension. Then you create a new sheet to extend the existing one and add the so created connectors to an input box.
        Great !
        Mmmm, not really appropriate in this case [/QUOTE]
        Thank you both for the "connectors" tip. I thought I was stuck, and .... got a solution
