Hello KNX-masters.
I hope you can help me find a solution for my issue.
I try to connect two KNX instalations through internet.
The first one has Gira HS, Gira S1, Synology NAS, WAGO PLC KNX, dynamic external IP, but with static hostname and KNX IP router.
The second one is much smaller KNX system with KNX IP router (based on WAGO PLC) and static external IP.
Both LANs are without advanced routers so I don't have a VPN connection to set up VPNs on routers.
I want to use one Gira HS for both instalations.
Has anybody tried this before?
How to do that?
How to do that?
