Crabtree 7172/EIB/HPC Program Files
    Hi!
    Has anyone happened to have the Crabtree ETS database, as i am looking for the Crabtree Platinum KNX 7172/EIB/HPC 2 Gang program application?
    Thanks in advance
    Mark
    Zuletzt geändert von MarkJulier; 11.05.2020, 20:35.
    Hi Mark, I do not have the 7172 APB but I have the 7174 which works fine, just ignore "Rocker B" parameters in ETS. I have attached the 7174 ETS files and 7176.
    The 7176 is a different binary, 7172/7174 appear compatible with each other. I have tested these on all three variants of the switch.
    These are OEM Siemens, their documentation also attached:
    crabtree_7172-7174_eib.zip
    crabtree_7176_eib.zip
      The Siemens switch 7172-7174 mentioned vd2 file can be found here:
      https://support.industry.siemens.com...dti=0&lc=en-SV
