Was halten Sie von der neuesten Firmware für tks-ip-gateway?
If you have to re-login 10 times to get a config done, because of connection lost & other errors, you hardly can call that fine.
Even logging in is taking ages.
Messages that configuration is paused because of active video connection, while this is not the case.
