dp/eib link
    dp/eib link
    code devices: 6gk14150aa01; n.2
    DP/EIB link
    led:
    power : green
    DP/BF:red
    EIB/BF:red
    programming: red
    BCD coding switch: 01 and 10
    I`m using STEP7 V5.4 and ETS3 V3.0d
    there were some problems relete to some devices (others) but both DP/EIB link where ok (no red led lit), after tryng to download an application for one device they went in this fault status;
    with ETS using "import" function i import the file DPEIB_A1.PR1 downloaded from SIEMENS customer support (GSD/ETS folder),
    but after imported it in ETS catalog i don t find any DP/EIB link , i see from manual that database file is called A1.Vdeib_a1.pr11D (?) ;
    both DP/EIB link dont answer if i try to download their ets address (programming led continues to flash );
    i attached ets file
    How can i solve it ?
    Really, maybe you post your problem again in your native language and then maybe someone can help. Cause I dont understand at all what you use and what you might have asked for?!
    Maybe I also only need a STEP 7 course for that
    Makki
    -> Bitte KEINE PNs!
      You must copy the dp/EIB Link from the Demo Projekt in your Projekt. It give's Not a vd file from the dp/eib Link. It is Not in the Produkt Library.
      MFG S.Meinert
        for roadflower: where can i find Demo Project?
          in this file DPEIB_A1.PR1 is the demo projekt. copy from hier in the new projekt.
          MFG S.Meinert
            ok i've done it, but i don t have 6GK14150AA01 in the catalog yet; is it correct?
              All right it's ok
              The new Modell for S7-300 ist from Helmholz.
              TP-EIB module for S7-300
              700-820-EIB01
              http://www.helmholz.de/prod.d,18_19_22.html?p_id=148
              MFG S.Meinert
