HAGER TYA610D Simultaneous manual and KNX Bus control?
    I'm thinking about buying HAGER TYA610D switching actuator to my existing KNX installation. What I'm not sure and I hope you will help me is if it can simultaneously control it manually(by buttons on device) and standard way by KNX bus like my other KNX devices?
    The reason for this question is device's manual which confuses me. It sounds like you can control it manually OR by bus, but not both the same time. I would like to be able to for example switch on channel on the device by button and switch it off by KNX bus without touching this Manual/Auto switch on the device. Is it actually possible?
    No it is not. So basically you set the switch to KNX, and when you do need a manual operation, you have to switch to manual first and then reset it to KNX.
    Regards Florian
      Thank you. That's what I thought. Although it does not make any sense to me...
        It is not so comon, but I think, it should not be a problem either, you just have to remember.
