Hello, does the PowerTool 1.2.2 software version no longer support panel configuration with 3.5-inch display? After the system crashes and after reinstalling Ets 5 (5.7.4) and importing the project, the prion panel configuration with display cannot be opened. PowerTool software does not start. Each device (Prion) in a single frame or in a double initiates PowerTool and can program without any problems. If an earlier version of PowerTool is installed, the application initiates errors and nothing can be done with Prion devices Has anyone had such problems? ,and anyone have any solution? Regards. Darek
Powertool 1.2.122
I would like to add that the PowerTool plugin initialization error occurs in Windows 7 (tested on 3 laptops) and Windows 10 (2).When adding a new device and selecting a triple frame with 3 single or triple buttons, after exiting the PowerTool and re-initiating the plug-in, you can easily program the devices.As soon as I add a 3.5-inch display to the device and exit PowerTool, reopening the PowerTool plug is not possible.
