KaControl KNX - Kampmann
    Hello
    Does anyone have experience with KaControl KNX - Kampmann?
    I have got few questions:
    - is this connection correct?
    - whether the 1 kOhm and 10 kOhm resistors should be connected only at the master - i.e. where the KNX card is or also on the other KaControl
    - whether the setting from the P54 controller "1" should be only for the master or also for other slaves
    - how the DIP switch (in KaControl Smartboard) should be set to master and how to slave.
    Thanks for the help
    Best regards
    zybi
    This gallery has 1 photos.
    KNX is master, you can the other controller omitting
    set P54 of 1
    the resistors must be connect on the mainboard
    kampmann has a knxproj with small or full connection to modbus and a top german support
