Hey, sorry for my english, but my 'deutsch' isn't that good. And it seem that you guys are the one who can help me out :$
Martin Koegler forwarded me to you guys in the hope that...
I'm trying to get the server LinuxMCE up and running, together with an IP 750 router. The IP-router has 1.1.1 as address.
I'm using the eibd of Martin, and at first sight, the communication is correct. When i push a light switch, my debug start to put a lot of info on my screen. When i run the command groupwrite, a lot of info is back in the debug. But the light isn't on.
I think that i must configure something in ETS (the IP router) in order to get this all running.
Does anybody give me a clue what i should do?
I start eibd with following command:
When i now push a lightswitch, i've got follwing debug output:
I've created in ETS a group address 0/0/3 with some lights (output relays) in. When i now run the command 'groupwrite ip:192.168.111.1 0/0/3 1', i've got following out in my debug:
Thanks for any hints!!!
/usr/bin/eibd -D -T -R -S -i -u --eibaddr=1.1.1 --no-tunnel-client-queuing -t1023 ipt:192.168.111.21
Layer 2(090AD680,4E4AA87E) Open Layer 0(090ADB78,4E4AA87E) Open Layer 0(090ADB78,4E4AA87E) Openend Layer 2(090AD680,4E4AA87E) Opened Layer 3(090CE290,4E4AA87E) Open Layer 8(090DE620,4E4AA87E) OpenInetSocket 6720 Layer 8(090DE620,4E4AA87E) InetSocket opened Layer 8(090EE970,4E4AA87E) OpenLocalSocket Layer 8(090EE970,4E4AA87E) LocalSocket opened Layer 8(090FECD0,4E4AA87E) Open Layer 0(090FED40,4E4AA87E) Open Layer 0(090FED40,4E4AA87E) Openend Layer 3(090CE290,4E4AA87E) registerBroadcast 090FECD0 Layer 3(090CE290,4E4AA87E) registerBroadcast 090FECD0 = 1 Layer 3(090CE290,4E4AA87E) registerGroup 090FECD0 Layer 3(090CE290,4E4AA87E) registerGroup 090FECD0 = 1 Layer 3(090CE290,4E4AA87E) registerIndividual 090FECD0 0 Layer 3(090CE290,4E4AA87E) registerIndividual 090FECD0 = 1 Layer 8(090FECD0,4E4AA87E) Opened Layer 4(0911F478,4E4AA87E) GroupCacheInit Layer 1(090ADB78,4E4AA87E) Send(020): 08 01 C0 A8 6F 01 0E 58 08 01 C0 A8 6F 01 0E 58 04 04 02 00 Layer 0(090ADB78,4E4AA87E) Send(026): 06 10 02 05 00 1A 08 01 C0 A8 6F 01 0E 58 08 01 C0 A8 6F 01 0E 58 04 04 02 00 Layer 0(090ADB78,4E4AA87E) Recv(020): 06 10 02 06 00 14 40 00 08 01 C0 A8 6F 15 0E 57 04 04 FF FF Layer 1(090ADB78,4E4AA87E) Recv(014): 40 00 08 01 C0 A8 6F 15 0E 57 04 04 FF FF Layer 0(090ADB78,4E4AA880) Recv(021): 06 10 04 20 00 15 04 40 00 00 29 00 B4 E0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Recv(015): 04 40 00 00 29 00 B4 E0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(004): 04 40 00 00 Layer 0(090ADB78,4E4AA880) Send(010): 06 10 04 21 00 0A 04 40 00 00 Layer 1(090AD680,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 2(090AD680,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 8(090FECD0,4E4AA880) Send_Route L_Data urgent from 1.1.12 to 1/1/212 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 1(090FED40,4E4AA880) Send(011): 29 00 B8 D0 11 0C 09 D4 01 00 81 Layer 0(090FED40,4E4AA880) Send(017): 06 10 05 30 00 11 29 00 B8 D0 11 0C 09 D4 01 00 81 Layer 0(090FED40,4E4AA880) Recv(017): 06 10 05 30 00 11 29 00 B4 D0 11 0C 09 D4 01 00 81 Layer 1(090FED40,4E4AA880) Recv(011): 29 00 B4 D0 11 0C 09 D4 01 00 81 Layer 8(090FECD0,4E4AA880) Recv_Route L_Data urgent from 1.1.12 to 1/1/212 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Send L_Data urgent from 1.1.12 to 1/1/212 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 2(090AD680,4E4AA880) Send L_Data urgent from 1.1.12 to 1/1/212 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 1(090AD680,4E4AA880) SendTunnel(015): 04 40 00 00 11 00 B8 C0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(015): 04 40 00 00 11 00 B8 C0 11 0C 09 D4 01 00 81 Layer 0(090ADB78,4E4AA880) Send(021): 06 10 04 20 00 15 04 40 00 00 11 00 B8 C0 11 0C 09 D4 01 00 81 Layer 2(090AD680,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 0(090ADB78,4E4AA880) Recv(010): 06 10 04 21 00 0A 04 40 00 00 Layer 1(090ADB78,4E4AA880) Recv(004): 04 40 00 00 Layer 0(090ADB78,4E4AA880) Recv(021): 06 10 04 20 00 15 04 40 01 00 29 00 B8 C0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Recv(015): 04 40 01 00 29 00 B8 C0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(004): 04 40 01 00 Layer 0(090ADB78,4E4AA880) Send(010): 06 10 04 21 00 0A 04 40 01 00 Layer 1(090AD680,4E4AA880) Recv L_Data normal from 1.1.12 to 1/1/212 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 2(090AD680,4E4AA880) Recv L_Data normal from 1.1.12 to 1/1/212 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Recv L_Data normal from 1.1.12 to 1/1/212 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 8(090FECD0,4E4AA880) Send_Route L_Data normal from 1.1.12 to 1/1/212 hops: 03 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 1(090FED40,4E4AA880) Send(011): 29 00 B4 B0 11 0C 09 D4 01 00 81 Layer 0(090FED40,4E4AA880) Send(017): 06 10 05 30 00 11 29 00 B4 B0 11 0C 09 D4 01 00 81 Layer 0(090ADB78,4E4AA880) Recv(021): 06 10 04 20 00 15 04 40 02 00 2E 00 B8 C0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Recv(015): 04 40 02 00 2E 00 B8 C0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(004): 04 40 02 00 Layer 0(090ADB78,4E4AA880) Send(010): 06 10 04 21 00 0A 04 40 02 00 Layer 0(090FED40,4E4AA880) Recv(017): 06 10 05 30 00 11 29 00 B8 B0 11 0C 09 D4 01 00 81 Layer 1(090FED40,4E4AA880) Recv(011): 29 00 B8 B0 11 0C 09 D4 01 00 81 Layer 8(090FECD0,4E4AA880) Recv_Route L_Data normal from 1.1.12 to 1/1/212 hops: 03 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Send L_Data normal from 1.1.12 to 1/1/212 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 2(090AD680,4E4AA880) Send L_Data normal from 1.1.12 to 1/1/212 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 1(090AD680,4E4AA880) SendTunnel(015): 04 40 01 00 11 00 B4 A0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(015): 04 40 01 00 11 00 B4 A0 11 0C 09 D4 01 00 81 Layer 0(090ADB78,4E4AA880) Send(021): 06 10 04 20 00 15 04 40 01 00 11 00 B4 A0 11 0C 09 D4 01 00 81 Layer 2(090AD680,4E4AA880) Recv L_Data normal from 1.1.12 to 1/1/212 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Recv L_Data normal from 1.1.12 to 1/1/212 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 0(090ADB78,4E4AA880) Recv(010): 06 10 04 21 00 0A 04 40 01 00 Layer 1(090ADB78,4E4AA880) Recv(004): 04 40 01 00 Layer 0(090ADB78,4E4AA880) Recv(021): 06 10 04 20 00 15 04 40 03 00 29 00 B4 A0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Recv(015): 04 40 03 00 29 00 B4 A0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(004): 04 40 03 00 Layer 0(090ADB78,4E4AA880) Send(010): 06 10 04 21 00 0A 04 40 03 00 Layer 1(090AD680,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 2(090AD680,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 8(090FECD0,4E4AA880) Send_Route L_Data urgent from 1.1.12 to 1/1/212 hops: 01 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 1(090FED40,4E4AA880) Send(011): 29 00 B8 90 11 0C 09 D4 01 00 81 Layer 0(090FED40,4E4AA880) Send(017): 06 10 05 30 00 11 29 00 B8 90 11 0C 09 D4 01 00 81 Layer 0(090ADB78,4E4AA880) Recv(021): 06 10 04 20 00 15 04 40 04 00 2E 00 B4 A0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Recv(015): 04 40 04 00 2E 00 B4 A0 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(004): 04 40 04 00 Layer 0(090ADB78,4E4AA880) Send(010): 06 10 04 21 00 0A 04 40 04 00 Layer 0(090FED40,4E4AA880) Recv(017): 06 10 05 30 00 11 29 00 B4 90 11 0C 09 D4 01 00 81 Layer 1(090FED40,4E4AA880) Recv(011): 29 00 B4 90 11 0C 09 D4 01 00 81 Layer 8(090FECD0,4E4AA880) Recv_Route L_Data urgent from 1.1.12 to 1/1/212 hops: 01 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Send L_Data urgent from 1.1.12 to 1/1/212 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 2(090AD680,4E4AA880) Send L_Data urgent from 1.1.12 to 1/1/212 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 1(090AD680,4E4AA880) SendTunnel(015): 04 40 02 00 11 00 B8 80 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(015): 04 40 02 00 11 00 B8 80 11 0C 09 D4 01 00 81 Layer 0(090ADB78,4E4AA880) Send(021): 06 10 04 20 00 15 04 40 02 00 11 00 B8 80 11 0C 09 D4 01 00 81 Layer 2(090AD680,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Recv L_Data urgent from 1.1.12 to 1/1/212 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 8(090FECD0,4E4AA880) SendDrop Layer 0(090ADB78,4E4AA880) Recv(010): 06 10 04 21 00 0A 04 40 02 00 Layer 1(090ADB78,4E4AA880) Recv(004): 04 40 02 00 Layer 0(090ADB78,4E4AA880) Recv(021): 06 10 04 20 00 15 04 40 05 00 29 00 B8 80 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Recv(015): 04 40 05 00 29 00 B8 80 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(004): 04 40 05 00 Layer 0(090ADB78,4E4AA880) Send(010): 06 10 04 21 00 0A 04 40 05 00 Layer 1(090AD680,4E4AA880) Recv L_Data normal from 1.1.12 to 1/1/212 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 2(090AD680,4E4AA880) Recv L_Data normal from 1.1.12 to 1/1/212 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 3(090CE290,4E4AA880) Recv L_Data normal from 1.1.12 to 1/1/212 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write (small) 01 Layer 8(090FECD0,4E4AA880) SendDrop Layer 0(090ADB78,4E4AA880) Recv(021): 06 10 04 20 00 15 04 40 06 00 2E 00 B8 80 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Recv(015): 04 40 06 00 2E 00 B8 80 11 0C 09 D4 01 00 81 Layer 1(090ADB78,4E4AA880) Send(004): 04 40 06 00 Layer 0(090ADB78,4E4AA880) Send(010): 06 10 04 21 00 0A 04 40 06 00 ^CLayer 8(090DE620,4E4AA882) StopServer Layer 8(090DE620,4E4AA882) Server ended Layer 8(090EE970,4E4AA882) StopServer Layer 8(090EE970,4E4AA882) Server ended Layer 8(090FECD0,4E4AA882) Close Layer 3(090CE290,4E4AA882) deregisterBroadcast 090FECD0 = 1 Layer 3(090CE290,4E4AA882) deregisterGroupCallBack 090FECD0 = 1 Layer 3(090CE290,4E4AA882) deregisterIndividual 090FECD0 = 1 Layer 0(090FED40,4E4AA882) Close Layer 4(0911F478,4E4AA882) GroupCacheDestroy Layer 4(0911F478,4E4AA882) GroupCacheClear Layer 3(090CE290,4E4AA882) Close Layer 2(090AD680,4E4AA882) Close Layer 1(090ADB78,4E4AA882) Send(010): 40 00 08 01 C0 A8 6F 01 0E 58 Layer 0(090ADB78,4E4AA882) Send(016): 06 10 02 09 00 10 40 00 08 01 C0 A8 6F 01 0E 58 Layer 0(090ADB78,4E4AA882) Close
Layer 2(093B5680,4E4AA8EB) Open Layer 0(093B5B78,4E4AA8EB) Open Layer 0(093B5B78,4E4AA8EB) Openend Layer 2(093B5680,4E4AA8EB) Opened Layer 3(093D6290,4E4AA8EB) Open Layer 8(093E6620,4E4AA8EB) OpenInetSocket 6720 Layer 8(093E6620,4E4AA8EB) InetSocket opened Layer 8(093F6970,4E4AA8EB) OpenLocalSocket Layer 8(093F6970,4E4AA8EB) LocalSocket opened Layer 8(09406CD0,4E4AA8EB) Open Layer 0(09406D40,4E4AA8EB) Open Layer 0(09406D40,4E4AA8EB) Openend Layer 3(093D6290,4E4AA8EB) registerBroadcast 09406CD0 Layer 3(093D6290,4E4AA8EB) registerBroadcast 09406CD0 = 1 Layer 3(093D6290,4E4AA8EB) registerGroup 09406CD0 Layer 3(093D6290,4E4AA8EB) registerGroup 09406CD0 = 1 Layer 3(093D6290,4E4AA8EB) registerIndividual 09406CD0 0 Layer 3(093D6290,4E4AA8EB) registerIndividual 09406CD0 = 1 Layer 8(09406CD0,4E4AA8EB) Opened Layer 4(09427478,4E4AA8EB) GroupCacheInit Layer 1(093B5B78,4E4AA8EB) Send(020): 08 01 C0 A8 6F 01 0E 58 08 01 C0 A8 6F 01 0E 58 04 04 02 00 Layer 0(093B5B78,4E4AA8EB) Send(026): 06 10 02 05 00 1A 08 01 C0 A8 6F 01 0E 58 08 01 C0 A8 6F 01 0E 58 04 04 02 00 Layer 0(093B5B78,4E4AA8EB) Recv(020): 06 10 02 06 00 14 41 00 08 01 C0 A8 6F 15 0E 57 04 04 FF FF Layer 1(093B5B78,4E4AA8EB) Recv(014): 41 00 08 01 C0 A8 6F 15 0E 57 04 04 FF FF Layer 8(093E6620,4E4AA8ED) New Connection Layer 8(09428060,4E4AA8ED) ClientConnection Init Layer 8(09428060,4E4AA8ED) RecvMessage(005): 00 22 00 03 FF Layer 7(094395F4,4E4AA8ED) OpenGroup Layer 4(094280A8,4E4AA8ED) OpenGroup 0/0/3 WO Layer 8(09428060,4E4AA8ED) SendMessage(002): 00 22 Layer 8(09428060,4E4AA8ED) RecvMessage(006): 00 25 00 80 01 01 Layer 7(094395F4,4E4AA8ED) Send(004): 00 80 01 01 Layer 4(094280A8,4E4AA8ED) Send Group T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8ED) Send L_Data low from 0.0.0 to 0/0/3 hops: 07 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8ED) Send L_Data low from 0.0.0 to 0/0/3 hops: 07 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 1(093B5680,4E4AA8ED) SendTunnel(017): 04 41 00 00 11 00 BC F0 00 00 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8ED) Send(017): 04 41 00 00 11 00 BC F0 00 00 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8ED) Send(023): 06 10 04 20 00 17 04 41 00 00 11 00 BC F0 00 00 00 03 03 00 80 01 01 Layer 7(094395F4,4E4AA8ED) CloseGroup Layer 2(093B5680,4E4AA8ED) Recv L_Data low from 0.0.0 to 0/0/3 hops: 07 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8ED) Recv L_Data low from 0.0.0 to 0/0/3 hops: 07 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 8(09406CD0,4E4AA8ED) Send_Route L_Data low from 0.0.0 to 0/0/3 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 1(09406D40,4E4AA8ED) Send(013): 29 00 BC E0 00 00 00 03 03 00 80 01 01 Layer 4(094280A8,4E4AA8ED) CloseGroup Layer 3(093D6290,4E4AA8ED) deregisterGroupCallBack 094280A8 = 0 Layer 8(09428060,4E4AA8ED) ClientConnection closed Layer 0(09406D40,4E4AA8ED) Send(019): 06 10 05 30 00 13 29 00 BC E0 00 00 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8ED) Recv(010): 06 10 04 21 00 0A 04 41 00 00 Layer 1(093B5B78,4E4AA8ED) Recv(004): 04 41 00 00 Layer 0(09406D40,4E4AA8EE) Recv(019): 06 10 05 30 00 13 29 00 BC F0 FF FF 00 03 03 00 80 01 01 Layer 1(09406D40,4E4AA8EE) Recv(013): 29 00 BC F0 FF FF 00 03 03 00 80 01 01 Layer 8(09406CD0,4E4AA8EE) Recv_Route L_Data low from 15.15.255 to 0/0/3 hops: 07 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Send L_Data low from 15.15.255 to 0/0/3 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8EE) Send L_Data low from 15.15.255 to 0/0/3 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8EE) Recv L_Data low from 15.15.255 to 0/0/3 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Recv L_Data low from 15.15.255 to 0/0/3 hops: 06 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 0(093B5B78,4E4AA8EE) Recv(023): 06 10 04 20 00 17 04 41 00 00 2E 00 BC F0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Recv(017): 04 41 00 00 2E 00 BC F0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(004): 04 41 00 00 Layer 0(093B5B78,4E4AA8EE) Send(010): 06 10 04 21 00 0A 04 41 00 00 Layer 1(093B5680,4E4AA8EE) SendTunnel(017): 04 41 01 00 11 00 BC E0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(017): 04 41 01 00 11 00 BC E0 FF FF 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8EE) Send(023): 06 10 04 20 00 17 04 41 01 00 11 00 BC E0 FF FF 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8EE) Recv(010): 06 10 04 21 00 0A 04 41 01 00 Layer 1(093B5B78,4E4AA8EE) Recv(004): 04 41 01 00 Layer 0(093B5B78,4E4AA8EE) Recv(023): 06 10 04 20 00 17 04 41 01 00 29 00 BC D0 00 00 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Recv(017): 04 41 01 00 29 00 BC D0 00 00 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(004): 04 41 01 00 Layer 0(093B5B78,4E4AA8EE) Send(010): 06 10 04 21 00 0A 04 41 01 00 Layer 1(093B5680,4E4AA8EE) Recv L_Data low from 0.0.0 to 0/0/3 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8EE) Recv L_Data low from 0.0.0 to 0/0/3 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Recv L_Data low from 0.0.0 to 0/0/3 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 8(09406CD0,4E4AA8EE) Send_Route L_Data low from 0.0.0 to 0/0/3 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 1(09406D40,4E4AA8EE) Send(013): 29 00 BC C0 00 00 00 03 03 00 80 01 01 Layer 0(09406D40,4E4AA8EE) Send(019): 06 10 05 30 00 13 29 00 BC C0 00 00 00 03 03 00 80 01 01 Layer 0(09406D40,4E4AA8EE) Recv(019): 06 10 05 30 00 13 29 00 BC D0 FF FF 00 03 03 00 80 01 01 Layer 1(09406D40,4E4AA8EE) Recv(013): 29 00 BC D0 FF FF 00 03 03 00 80 01 01 Layer 8(09406CD0,4E4AA8EE) Recv_Route L_Data low from 15.15.255 to 0/0/3 hops: 05 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Send L_Data low from 15.15.255 to 0/0/3 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8EE) Send L_Data low from 15.15.255 to 0/0/3 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8EE) Recv L_Data low from 15.15.255 to 0/0/3 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Recv L_Data low from 15.15.255 to 0/0/3 hops: 04 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 0(093B5B78,4E4AA8EE) Recv(023): 06 10 04 20 00 17 04 41 02 00 2E 00 BC E0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Recv(017): 04 41 02 00 2E 00 BC E0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(004): 04 41 02 00 Layer 0(093B5B78,4E4AA8EE) Send(010): 06 10 04 21 00 0A 04 41 02 00 Layer 1(093B5680,4E4AA8EE) SendTunnel(017): 04 41 02 00 11 00 BC C0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(017): 04 41 02 00 11 00 BC C0 FF FF 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8EE) Send(023): 06 10 04 20 00 17 04 41 02 00 11 00 BC C0 FF FF 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8EE) Recv(010): 06 10 04 21 00 0A 04 41 02 00 Layer 1(093B5B78,4E4AA8EE) Recv(004): 04 41 02 00 Layer 0(093B5B78,4E4AA8EE) Recv(023): 06 10 04 20 00 17 04 41 03 00 29 00 BC B0 00 00 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Recv(017): 04 41 03 00 29 00 BC B0 00 00 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(004): 04 41 03 00 Layer 0(093B5B78,4E4AA8EE) Send(010): 06 10 04 21 00 0A 04 41 03 00 Layer 1(093B5680,4E4AA8EE) Recv L_Data low from 0.0.0 to 0/0/3 hops: 03 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8EE) Recv L_Data low from 0.0.0 to 0/0/3 hops: 03 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Recv L_Data low from 0.0.0 to 0/0/3 hops: 03 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 8(09406CD0,4E4AA8EE) Send_Route L_Data low from 0.0.0 to 0/0/3 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 1(09406D40,4E4AA8EE) Send(013): 29 00 BC A0 00 00 00 03 03 00 80 01 01 Layer 0(09406D40,4E4AA8EE) Send(019): 06 10 05 30 00 13 29 00 BC A0 00 00 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8EE) Recv(023): 06 10 04 20 00 17 04 41 04 00 2E 00 BC C0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Recv(017): 04 41 04 00 2E 00 BC C0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(004): 04 41 04 00 Layer 0(093B5B78,4E4AA8EE) Send(010): 06 10 04 21 00 0A 04 41 04 00 Layer 0(09406D40,4E4AA8EE) Recv(019): 06 10 05 30 00 13 29 00 BC B0 FF FF 00 03 03 00 80 01 01 Layer 1(09406D40,4E4AA8EE) Recv(013): 29 00 BC B0 FF FF 00 03 03 00 80 01 01 Layer 8(09406CD0,4E4AA8EE) Recv_Route L_Data low from 15.15.255 to 0/0/3 hops: 03 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Send L_Data low from 15.15.255 to 0/0/3 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8EE) Send L_Data low from 15.15.255 to 0/0/3 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 1(093B5680,4E4AA8EE) SendTunnel(017): 04 41 03 00 11 00 BC A0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(017): 04 41 03 00 11 00 BC A0 FF FF 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8EE) Send(023): 06 10 04 20 00 17 04 41 03 00 11 00 BC A0 FF FF 00 03 03 00 80 01 01 Layer 2(093B5680,4E4AA8EE) Recv L_Data low from 15.15.255 to 0/0/3 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Recv L_Data low from 15.15.255 to 0/0/3 hops: 02 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 0(093B5B78,4E4AA8EE) Recv(010): 06 10 04 21 00 0A 04 41 03 00 Layer 1(093B5B78,4E4AA8EE) Recv(004): 04 41 03 00 Layer 0(093B5B78,4E4AA8EE) Recv(023): 06 10 04 20 00 17 04 41 05 00 29 00 BC 90 00 00 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Recv(017): 04 41 05 00 29 00 BC 90 00 00 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(004): 04 41 05 00 Layer 0(093B5B78,4E4AA8EE) Send(010): 06 10 04 21 00 0A 04 41 05 00 Layer 1(093B5680,4E4AA8EE) Recv L_Data low from 0.0.0 to 0/0/3 hops: 01 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8EE) Recv L_Data low from 0.0.0 to 0/0/3 hops: 01 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Recv L_Data low from 0.0.0 to 0/0/3 hops: 01 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 8(09406CD0,4E4AA8EE) Send_Route L_Data low from 0.0.0 to 0/0/3 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 1(09406D40,4E4AA8EE) Send(013): 29 00 BC 80 00 00 00 03 03 00 80 01 01 Layer 0(09406D40,4E4AA8EE) Send(019): 06 10 05 30 00 13 29 00 BC 80 00 00 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8EE) Recv(023): 06 10 04 20 00 17 04 41 06 00 2E 00 BC A0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Recv(017): 04 41 06 00 2E 00 BC A0 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(004): 04 41 06 00 Layer 0(093B5B78,4E4AA8EE) Send(010): 06 10 04 21 00 0A 04 41 06 00 Layer 0(09406D40,4E4AA8EE) Recv(019): 06 10 05 30 00 13 29 00 BC 90 FF FF 00 03 03 00 80 01 01 Layer 1(09406D40,4E4AA8EE) Recv(013): 29 00 BC 90 FF FF 00 03 03 00 80 01 01 Layer 8(09406CD0,4E4AA8EE) Recv_Route L_Data low from 15.15.255 to 0/0/3 hops: 01 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Send L_Data low from 15.15.255 to 0/0/3 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 2(093B5680,4E4AA8EE) Send L_Data low from 15.15.255 to 0/0/3 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 1(093B5680,4E4AA8EE) SendTunnel(017): 04 41 04 00 11 00 BC 80 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(017): 04 41 04 00 11 00 BC 80 FF FF 00 03 03 00 80 01 01 Layer 0(093B5B78,4E4AA8EE) Send(023): 06 10 04 20 00 17 04 41 04 00 11 00 BC 80 FF FF 00 03 03 00 80 01 01 Layer 2(093B5680,4E4AA8EE) Recv L_Data low from 15.15.255 to 0/0/3 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 3(093D6290,4E4AA8EE) Recv L_Data low from 15.15.255 to 0/0/3 hops: 00 T_DATA_XXX_REQ A_GroupValue_Write 01 01 Layer 8(09406CD0,4E4AA8EE) SendDrop Layer 0(093B5B78,4E4AA8EE) Recv(010): 06 10 04 21 00 0A 04 41 04 00 Layer 1(093B5B78,4E4AA8EE) Recv(004): 04 41 04 00 Layer 0(093B5B78,4E4AA8EE) Recv(023): 06 10 04 20 00 17 04 41 07 00 2E 00 BC 80 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Recv(017): 04 41 07 00 2E 00 BC 80 FF FF 00 03 03 00 80 01 01 Layer 1(093B5B78,4E4AA8EE) Send(004): 04 41 07 00 Layer 0(093B5B78,4E4AA8EE) Send(010): 06 10 04 21 00 0A 04 41 07 00 ^CLayer 8(093E6620,4E4AA8EF) StopServer Layer 8(093E6620,4E4AA8EF) Server ended Layer 8(093F6970,4E4AA8EF) StopServer Layer 8(093F6970,4E4AA8EF) Server ended Layer 8(09406CD0,4E4AA8EF) Close Layer 3(093D6290,4E4AA8EF) deregisterBroadcast 09406CD0 = 1 Layer 3(093D6290,4E4AA8EF) deregisterGroupCallBack 09406CD0 = 1 Layer 3(093D6290,4E4AA8EF) deregisterIndividual 09406CD0 = 1 Layer 0(09406D40,4E4AA8EF) Close Layer 4(09427478,4E4AA8EF) GroupCacheDestroy Layer 4(09427478,4E4AA8EF) GroupCacheClear Layer 3(093D6290,4E4AA8EF) Close Layer 2(093B5680,4E4AA8EF) Close Layer 1(093B5B78,4E4AA8EF) Send(010): 41 00 08 01 C0 A8 6F 01 0E 58 Layer 0(093B5B78,4E4AA8EF) Send(016): 06 10 02 09 00 10 41 00 08 01 C0 A8 6F 01 0E 58 Layer 0(093B5B78,4E4AA8EF) Close
