linknx ERROR : Unable to load config: Couldn't load /linknx.xml
A have a error message on Ubuntu?
linknx ERROR : Unable to load config: Couldn't load /linknx.xml <ticpp.cpp@784>
My command is: linknx --config/=linknx.xml
Thanks your answers, but it not work.
The linknx is on the /usr/local/bin/ , and the linknx.xml is alredy.
When i run simply linknx command then it works but the knxweb give a error:
Objectcontroller: object ID not found.
But the object is in the linknx.xml file.
Interestingly your pasted file loads without errors with my linknx. The error you post normally means a syntax error in the XML file. As the default file doesn't match with your environment anyway just start with a minium file like this
