Hallo Tom,
gibt es irgendwo eine Anleitung für Laien?
Gruß Claus
Gruß Claus
umask 0022
export WORKDIR_EIBD=/home/freetz/src
mkdir $WORKDIR_EIBD
# // Setup Cross Compiler
mkdir $WORKDIR_EIBD/freetz
cd $WORKDIR_EIBD/freetz
#svn co http://svn.freetz.org/trunk/
#cd $WORKDIR_EIBD/freetz/trunk
svn checkout http://svn.freetz.org/branches/freetz-stable-1.2 freetz-stable-1.2-eibd
cd $WORKDIR_EIBD/freetz/freetz-stable-1.2-eibd
make menuconfig
make precompiled
# // kaffeepause
export TOOLCHAIN=$WORKDIR_EIBD/freetz/freetz-stable-1.2-eibd/toolchain/target
export PATH=$TOOLCHAIN/bin:$PATH
export AR=$TOOLCHAIN/bin/mipsel-linux-uclibc-ar
export AS=$TOOLCHAIN/bin/mipsel-linux-uclibc-as
export LD=$TOOLCHAIN/bin/mipsel-linux-uclibc-ld
export NM=$TOOLCHAIN/bin/mipsel-linux-uclibc-nm
export CC=$TOOLCHAIN/bin/mipsel-linux-uclibc-gcc
export CPP=$TOOLCHAIN/bin/mipsel-linux-uclibc-cpp
export GCC=$TOOLCHAIN/bin/mipsel-linux-uclibc-gcc
export CXX=$TOOLCHAIN/bin/mipsel-linux-uclibc-g++-wrapper
export RANLIB=$TOOLCHAIN/bin/mipsel-linux-uclibc-ranlib
export STRIP=$TOOLCHAIN/bin/mipsel-linux-uclibc-strip
export CROSS_ARCH=mipsel-linux-uclibc
export CROSS_BUILD=i386-pc-linux-gnu
export CPPFLAGS="-static -static-libgcc -lstdc++ -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -static -I$TOOLCHAIN/include"
export LDFLAGS="-static -L$TOOLCHAIN/lib"
export CROSS_OUT=$WORKDIR_EIBD/cross_out
mkdir $CROSS_OUT
cd $WORKDIR_EIBD
wget http://www.auto.tuwien.ac.at/~mkoegler/pth/pthsem_2.0.8.tar.gz
wget http://www.auto.tuwien.ac.at/~mkoegler/eib/argp-standalone-1.3.tar.gz
wget http://www.auto.tuwien.ac.at/~mkoegler/eib/bcusdk_0.0.5.tar.gz
tar -xvzf pthsem_2.0.8.tar.gz
tar -xvzf argp-standalone-1.3.tar.gz
tar -xvzf bcusdk_0.0.5.tar.gz
cd $WORKDIR_EIBD/argp-standalone-1.3/
./configure --prefix=$CROSS_OUT --build=$CROSS_BUILD --host=$CROSS_ARCH --target=$CROSS_ARCH
make && make install
cd $WORKDIR_EIBD/pthsem-2.0.8
# ohne mctx-Optionen kein Kompile unter linux >3.0
./configure --prefix=$CROSS_OUT --build=$CROSS_BUILD --host=$CROSS_ARCH --target=$CROSS_ARCH --enable-shared=no --with-mctx-mth=sjlj --with-mctx-dsp=ssjlj --with-mctx-stk=sas
cd $WORKDIR_EIBD
cat << EOF > ./eibd_1.patch
--- bcusdk-0.0.5/eibd/usb/linux_usbfs.c.orig 2011-01-26 11:50:08.000000000 +0100
+++ bcusdk-0.0.5/eibd/usb/linux_usbfs.c 2011-08-25 22:57:29.000000000 +0200
@@ -52,7 +52,8 @@
return 0;
-int clock_gettime(clockid_t clk_id, struct timespec *tp)
+#define clock_gettime(A,B) xclock_gettime(A, B)
+int xclock_gettime(clockid_t clk_id, struct timespec *tp)
pth_int_time (tp);
return 0;
EOF
echo "PATCH 1"
patch ./bcusdk-0.0.5/eibd/usb/linux_usbfs.c eibd_1.patch || exit
cat << EOF > ./eibd_2.patch
--- a/eibd/server/eibd.cpp
+++ b/eibd/server/eibd.cpp
@@ -358,7 +358,7 @@ main (int ac, char *ag[])
l2 = Create (ag[index], arg.backendflags, &t);
- if (!l2->init ())
+ if (!l2 || !l2->init ())
die ("initialisation of the backend failed");
l3 = new Layer3 (l2, &t);
if (arg.port)
EOF
echo "PATCH 2"
patch ./bcusdk-0.0.5/eibd/server/eibd.cpp eibd_2.patch || exit
cd $WORKDIR_EIBD/bcusdk-0.0.5
export CPPFLAGS="-static -static-libgcc -lstdc++ -Wl,-rpath -Wl,/var/media/ftp/add_on/lib -march=24kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -static -I$TOOLCHAIN/include -static -I$CROSS_OUT/include"
export LDFLAGS="-static -L$TOOLCHAIN/lib -static -L$CROSS_OUT/lib"
#./configure --enable-shared=no --prefix=$CROSS_OUT --build=$CROSS_BUILD --host=$CROSS_ARCH --target=$CROSS_ARCH --with-pth=$CROSS_OUT --without-pth-test --enable-onlyeibd --enable-eibnetiptunnel --enable-eibnetipserver --enable-groupcache --enable-usb
$STRIP $CROSS_OUT/bin/eibd
$STRIP $CROSS_OUT/bin/groupswrite
root@fritz:/var/mod/root# export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/var/media/ftp/uStor01/EIB/lib root@fritz:/var/mod/root# echo $LD_LIBRARY_PATH /mod/lib:/var/media/ftp/uStor01/EIB/lib root@fritz:/var/mod/root# cd /var/media/ftp/uStor01/EIB/bin root@fritz:/var/media/ftp/uStor01/EIB/bin# ./eibd -d -i --no-tunnel-client-queuing ipt:192.168.178.19 W00000001: EIBD should not run as root root@fritz:/var/media/ftp/uStor01/EIB/bin# ./groupswrite ip:127.0.0.1 3/4/0 1 # Licht an Send request root@fritz:/var/media/ftp/uStor01/EIB/bin# ./groupswrite ip:127.0.0.1 3/4/0 0 # Licht aus Send request
#!/bin/sh
#SET BASEDIR
BASEDIR=/var/media/ftp/add_on
#Check if folder exists
while ! [ -d $BASEDIR ] ; do sleep 5; done
#Look for start script on box
for f in $BASEDIR; do
cd $f
if [ -x start.sh ]; then
sleep 60
$f/start.sh
fi
done
# send script to background so the other stuff in debug.cfg will get executed
done &
ERROR: kernel image is 1131776 bytes too big. See http://freetz.org/wiki/FAQ#Filesystemimagetoobig for details.
