Heizung template fur TS2+
    HS/FS Heizung template fur TS2+
    Hello,
    i modified the 0-4 template (Heizung) and i created a new 0-99 template (Heizung ts2).
    This new template works exactly like the normal "Heizung", but it doesn't send the default module soll_temp (22° for Comfort, 11° for frost protection, etc) when you switch from a betriebsmodi to another betriebsmodi.
    Note that this template does not work on iphone/ipad.
    For installation, unzip the 0-99.zip, select QuadClient menu from Expert software, then import template.
