HS4 / Value transformation logic block
    Hello all,
    Does anybody have any ideas of an existing logic block or tips as to the best solution for the following problem.
    I have a need to be able to transform a number of input values from a AC interface device in order to function with a existing QuadClient plug-in.
    For example the device sends a value of 3 and I need this to be transformed to a 1 and sent on to the Plug-in. As an example the following:
    Original value : New value:
    3 0
    2 1
    1 2
    Is there any know logic block where all alternatives can be defined and stored?
    Many thanks in beforehand
    //Rolf
    Hi Rolf!
    For those use cases I take "Fall-Prüfung (<=) 8-fach" - see attached little logic.
    Best regards
      Perfect!
      Many thanks Hightech.....
      //Rolf
