I need to call a CO every the 1. of a month.. is there any way in Gira Homeserver i can do that.. Can't seem to get the universal timer to work.. i can't set a time...
You mean you want to set the CO to a special value on the beginning of the month, at midnight on 1st of month? Have a look on logic module 12278 Impulsgenerator. You find it in the download section. On exit A4 it sends the number of the month just on the change of month. With that trigger you can set the object in the "Ausgangsbox".
BR
Olaf
