EIB/DPLink with ETS3
    It is possible to use ETS3 to program this device?
    Yes__
    www.knXpresso.com
      thank you, how can i understand if the application i'm going to download in the EIB/DP link is the right one?
        Locate the application program?
        www.knXpresso.com
          sorry i don t understand "locate"
            I guess he means
            Where is the application program ?
            i.e. in which location ?
            Can you provide a URL to the download of the application (and documentation maybe ?)
              see Appendix
              www.knXpresso.com
                Zitat von Michael H Beitrag anzeigen
                see Appendix
                Thanks Michael i need application program for 6GK14150AA01,i think this PROJ_V11.PR1 is for 6GK14150AA00?
                  Copy the item out of the Project in your project. That's it. It give not a application for this item
                  MFG S.Meinert
                    ok, thanks
                    in the property of the device in the project PROJ_V11.PR1 i read: "code device: 6GK14150AA00"; if i download it to my device (6GK14150AA00) i 'm afraid
                    it doesn 't work and the device won't work anymore (it's happened);
                    what do you think? i'm wrong?
                    thanks again
                      We blocked the equipment with a well-known car manufacturer over 10x and we to have the equipment only copied. Everything runs like it is. Then one of Siemens has the rest programmed in S5 or S7. There I cannot say unfortunately much.
                      MFG S.Meinert
                        sorry i don't understand almost anything; did you download that database into 6GK14150AA01 and it works?
                          I see myself on Monday to which equipment was blocked
                          MFG S.Meinert
