Using a relay couln mean the load on the 103800 outputs are too low, and could couse the contacts to stick together, because there are never sparks to clean the contact surface.
Also, an advantage of the 104600 is the load recognition/ curent measurement. This can be used to set ana alarm when a pump brakes down i.e.
