ETS 3 bus monitor problem?
    Hi all,
    First of all, my german isn't that good, so I hope nobody minds that I ask the questions in English.
    I have a strange problem, for wich nobody I allready talked to has an answer for.
    In the online monitor in ETS 3, where you can follow the bus-telegrams in realtime, i get a flood of the same 2 items over and over again, flooding the monitor window.
    I don't know where to search anymore, and I really hope one of you experts can help me out here...
    Kind regards,
    What is for equipment 1.1.1?
    Did they query already the equipment info. + the group addresses from 1.1.1?
    MFG S.Meinert
      Address 1.1.1 is from what I can see, the connection to the "system" ?
      There isn't a group address 0/1/5 in my groupadresses window. A very strange problem, so the equipment info gives an error saying that he can't find anything...
        What for equipment is USB or IP?
        There is a SPS attached over IP?
        Already another interface tries?
        Perhaps the interface is damage.
        MFG S.Meinert
          Perhaps the interface is defective.
          The interface is a IP connection (EIBlib/IP) trough a Gira 1080 00 USB (iETS) All other things like programming are working fine, so I don't think it is malfunctioning?
          I don't really know what you mean with an SPS?
            SPS is a PLC (programmable logic controller)
              Found the problem... A code in the Graphic logic editor was sending out all these messages. Cleaned out the GLE and the flood is gone...
