Telegram for nightshift pushbuttons
    ETS Telegram for nightshift pushbuttons
    Hi all!
    I was hoping someone here could help me out with a small issue. I'm using Gira pushbuttons throughout my house and I want to enable the pushbutton brightness nightshift function for my bedrooms. However i cant seem to figure out how to trigger this function at a specific time. How can I send a cyclic 1 bit telegram for enabling this function in the evening, and a 0 bit telegram for dissabling it in the morning?
    Thanks for any advice on this.
    You either need a logic server, weather station or a clock module to generate this message. How do you get the time signal to the switches? Maybe there is a function to trigger your daylight message.
    I use a logic like if light in room off and dark (from weather station) than dark mode
      Thanks for reply! I'm using the Gira S1 to get the time signal, but I cant find any functionatlity for sending telegrams at specific times. Not sure if its possible with the S1? I am planning to by a Homeserver further down the line, but not sure when it will be. The clock module might be the easiest and cheapest solution? As long as it can send telegrams at specific hours.
      Zuletzt geändert von fkaasin; 28.08.2021, 19:13.
        Norwegisch ist jetzt nicht gerade meine Muttersprache, aber du kannst ja auch den Google Übersetzer nehmen.
        X1, just take a switch to create the signal and then you can use the „Funktionsuhr“ in the X1 Visu, or there are timers, you can programm, but you have to enable these settings in the project settings of the GPA.
          Sorry but S1 != X1.
            Kleinigkeiten, Sorry
              Using a HS, this is quite simple
              Do you have any logic module or are keen programming an Arduiono / Raspberry Py?
              Otherwise, have a look on the Merten device MEG6606-0008 to get the search pattern.
                No unfortunately I dont have any logic modul, yet. Nor do I have any experience in programming Ardunio/Rasberry. But that Merten device seems like a great choice! Thanks
