ETS6 Gira Tastsensor 3 plugin crash.
    Hi
    ETS6 crashes if i open the parameter window of my Gira Tastsensor 3. It closes without giving any error. Some of you tested ETS6 with this plugin as well?
    Could you please file a bug report at support.knx.org?
      Workaround: You have to selected a bus interface.
        @GGehlfeldt You made my day! It works.
        Many thanks for this hint!!!
          Hello gentlemen,
          We will have a look at it! Please keep in mind that you can always drop a message to support@knx.org to report this (always including your diagnostic files).
          Regards,
          Vassilios
            @valour thanks.
            Please look also at the KNX interface selection. Once you open ETS6, it reverts everytime to "Automatic", instead of retain the selected one.
              Zitat von TheMax74 Beitrag anzeigen
              @valour thanks.
              The automatic shall always work. The current selection is meant to be used for this session only, it does not remember the setting. It could well be that the automatic picks the connection you want to use.
              Moreover, if you add the interface in your project, then you actually help ETS to select the right connection 😉
                Ok, but the problem is, that if it reverts to "automatic" and i don't notice it, whenever i try to open the Gira plugin, ETS crashes, loosing all work done in that session. This can be painful.
                  We will fix this in 6.0.1. Again, if you follow the instruction to add the interface in your project, then you can configure the automatic in a way that does not use it. See here: https://support.knx.org/hc/en-us/art...ection-manager
                    Hallo ich hätte das gleiche Problem nur bekomme ich es nicht behoben indem ich meine USB Schnittstelle hinzufüge.
                    Gibt es noch eine andere Lösung oder habe ich etwas falsch verstanden.
                      Ich weiß ja nicht, welche USB-Schnittstelle du hast, aber wenn es eine ist, bei der nicht unterhalb des Gerätesymbols noch das Schnittstellensymbol auftaucht, kann die ETS die nicht auomatisch erkennen.
                      In diesem Fall musst du, bevor du das Gira Tastsensor 3 plugin aufrufst, rechts oben in der ETS eine Schnittstelle auswählen.
                      Das wird in der ETS 6.0.1 behoben sein. Und nein, ich weiß nicht, wann die releast wird.
