Archive, unsollicited entry
    I've written a Baustein to archive some data (IP address).
    This works fine, except that I've an unsollicited entry at each HS reboot (line full of 0)..... and I do many reboots
    How can I avoid this ?
    I was thinking about a condition in the 5012 line, but can't find it .
    Thank you for any tip.
    Hi Raymond,
    will the module be calculated at reboot (last parameter of the 5001-line)?
    Do you evaluate the 'EI'-parameter?
    Without knowing the code of your module, a line like the following might help:
    5012|1|"EI"|"0"|""|0|0|0|0
    Gruß, Rainer
      Hi Rainer,
      Thank you for the reply
      My 5001 line looks like this
      5001|2|4|0|2|0
      So, no, I guess
      Aaarg, I've overlooked it, but
      EI==0
      doesn't do it.
      Maybe I should take care of the problem in the usage of the Baustein (not in the Baustein itself) ?
        Hello Raymond,
        Its hard to help without seeing the logic and the full logic module code. But if you use the "EI==0" condition while sending a value it should not be sent at boot time.
        Cheers,
        Gaston
