[HowTo] Eibd unter Windows
  • MikeMelga
    No one?
  • MikeMelga
    Still trying with no success.
    When I run eibnetsearch (included in eibd) without running eibd I get the following result:
    Asking 224.0.23.12 at port 3671 from port 3672
    Answer from 192.168.0.20 at port 3671
    Medium: 2
    State: 0
    Addr: 1.1.17
    InstallID: 0
    Serial: 00 C5 07 04 00 74
    Multicast-Addr: 0.0.0.0
    MAC: 00 50 C2 55 4E 21
    Name: KNX IP BAOS 770
    Service 2 Version 1
    Service 3 Version 1
    Service 4 Version 1
    When I run it after running eibd (eibd -S -T -D -i ipt:192.168.0.20) I get this:
    IP initialisation failed
    What is wrong?
  • MikeMelga
    Hi.
    I am also trying to configure eibd under windows but I'm still a bit confused
    I am trying to connect a Gira Homeserver to my KNX bus using a Weinzierl BAOS 770 IP interface (no routing).
    I still haven't managed to access the KNX bus using the HS.
    Can someone help me?
    I have to play with 3 IP addresses:
    192.168.0.22 - Gira HS3
    192.168.0.20 - Weinzierl BAOS 770
    192.168.0.12 - Windows Machine
    I start eibd with:
    It apparently runs with no error.
    Now...I've configured the Gira HS using the expert software to set the bus access to EIBNet IP/Routing but I don't know exactly what IP should I use.
    I tried leaving the multicast address (224.0.23.12:3671) but still can't access the bus.
    I've thought of using the eibd's IP address but don't know which port to use :P
    I don't know what to do next
    What am I doing wrong?
    How can I check if eibd is working?
    Thanks.
  • Mstyle
    Wenn ich den Dienst ohne -S starte startet er ohne Probleme.
  • Mstyle
    Hallo
    Ich habe es auf Win7 64bit und auf Win8 64bit versucht.
    Ich habe auch das starten als Administrator ausprobiert leider ohne erfolg.
    Gruss Tom
  • mkeil
    Hmm. das paket läuft hier stabil auf einem win2003 server.
    Welches OS setzt du ein? wenn Win7 hast du mal starten als administrator probiert?
    Ich meine aber das ich den eibd auch schon mal unter win7 64bit testhalber am laufen hatte.
  • Mstyle
    EIBD Startet nicht als Server
    Hallo
    Ich habe dein Zipfile von deiner Webseite gezogen und versuche nun verzweifelt den eibd als server zu starten wie beim Kolgen zuvor erhalte ich folgenden Fehler:
    C:\Users\Mstyle\Downloads\eibd-win32>eibd -S -T -D -i -t255 ipt:192.168.2.222
    Layer 7(00000000,5124CB9C) EIBD should not run as root
    W00000001: EIBD should not run as root
    Layer 2(00C11F50,5124CB9C) Open
    Layer 0(00C12148,5124CB9C) Open
    Layer 0(00C12148,5124CB9C) Openend
    Layer 2(00C11F50,5124CB9C) Opened
    Layer 3(00C32590,5124CB9C) Open
    Layer 0(00C529E8,5124CB9C) Open
    Layer 0(00C529E8,5124CB9C) Openend
    Layer 0(00C529E8,5124CB9C) Close
    Layer 1(00C12148,5124CB9C) Send(020): 08 01 C0 A8 02 43 0E 58 08 01 C0 A8 02 43
    0E 58 04 04 02 00
    Layer 0(00C12148,5124CB9C) Send(026): 06 10 02 05 00 1A 08 01 C0 A8 02 43 0E 58
    08 01 C0 A8 02 43 0E 58 04 04 02 00
    initilization of the EIBnet/IP server failed
    Wo soll ich suchen?
    Firewall ist aus
    Tunneling und Routing habe ich probiert.
    Ich sehe auch kein Tool das auf den Port hört.
    C:\Users\Mstyle>netstat -a
    Aktive Verbindungen
    Proto Lokale Adresse Remoteadresse Status
    TCP 0.0.0.0:80 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:135 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:445 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:554 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:623 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:1801 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:1947 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:2103 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:2105 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:2107 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:2179 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:2869 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:5357 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:5800 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:5900 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:9969 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:10243 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:16992 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:17500 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:32032 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:49152 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:49153 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:49154 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:49156 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:49161 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:49165 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:49166 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:49436 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:50420 Mstyle-HP:0 ABHÖREN
    TCP 0.0.0.0:55859 Mstyle-HP:0 ABHÖREN
    TCP 127.0.0.1:944 Mstyle-HP:0 ABHÖREN
    TCP 127.0.0.1:5354 Mstyle-HP:0 ABHÖREN
    TCP 127.0.0.1:5354 Mstyle-HP:49155 HERGESTELLT
    TCP 127.0.0.1:5354 Mstyle-HP:49159 HERGESTELLT
    TCP 127.0.0.1:5354 Mstyle-HP:49171 HERGESTELLT
    TCP 127.0.0.1:5354 Mstyle-HP:49176 HERGESTELLT
    TCP 127.0.0.1:5354 Mstyle-HP:49382 HERGESTELLT
    TCP 127.0.0.1:5354 Mstyle-HP:49606 HERGESTELLT
    TCP 127.0.0.1:5354 Mstyle-HP:49607 HERGESTELLT
    TCP 127.0.0.1:5354 Mstyle-HP:49608 HERGESTELLT
    TCP 127.0.0.1:5940 Mstyle-HP:0 ABHÖREN
    TCP 127.0.0.1:5940 Mstyle-HP:49169 HERGESTELLT
    TCP 127.0.0.1:19872 Mstyle-HP:49421 HERGESTELLT
    TCP 127.0.0.1:27015 Mstyle-HP:0 ABHÖREN
    TCP 127.0.0.1:27015 Mstyle-HP:49178 HERGESTELLT
    TCP 127.0.0.1:49155 Mstyle-HP:5354 HERGESTELLT
    TCP 127.0.0.1:49157 Mstyle-HP:49158 HERGESTELLT
    TCP 127.0.0.1:49158 Mstyle-HP:49157 HERGESTELLT
    TCP 127.0.0.1:49159 Mstyle-HP:5354 HERGESTELLT
    TCP 127.0.0.1:49167 Mstyle-HP:49168 HERGESTELLT
    TCP 127.0.0.1:49168 Mstyle-HP:49167 HERGESTELLT
    TCP 127.0.0.1:49169 Mstyle-HP:5940 HERGESTELLT
    TCP 127.0.0.1:49171 Mstyle-HP:5354 HERGESTELLT
    TCP 127.0.0.1:49176 Mstyle-HP:5354 HERGESTELLT
    TCP 127.0.0.1:49177 Mstyle-HP:0 ABHÖREN
    TCP 127.0.0.1:49178 Mstyle-HP:27015 HERGESTELLT
    TCP 127.0.0.1:49203 Mstyle-HP:0 ABHÖREN
    TCP 127.0.0.1:49382 Mstyle-HP:5354 HERGESTELLT
    TCP 127.0.0.1:49421 Mstyle-HP:19872 HERGESTELLT
    TCP 127.0.0.1:49606 Mstyle-HP:5354 HERGESTELLT
    TCP 127.0.0.1:49607 Mstyle-HP:5354 HERGESTELLT
    TCP 127.0.0.1:49608 Mstyle-HP:5354 HERGESTELLT
    TCP 127.0.0.1:50357 Mstyle-HP:0 ABHÖREN
    TCP 127.0.0.1:50420 Mstyle-HP:0 ABHÖREN
    TCP 127.0.0.1:50872 Mstyle-HP:50873 HERGESTELLT
    TCP 127.0.0.1:50873 Mstyle-HP:50872 HERGESTELLT
    TCP 192.168.2.67:139 Mstyle-HP:0 ABHÖREN
    TCP 192.168.2.67:17500 MSTYLE-PC:52596 HERGESTELLT
    TCP 192.168.2.67:17500 MSTYLE-PC:53488 HERGESTELLT
    TCP 192.168.2.67:17500 Elvira-PC:51853 HERGESTELLT
    TCP 192.168.2.67:17500 ELVIRA-PC:52448 HERGESTELLT
    TCP 192.168.2.67:17500 CABALZAR-NOTE:54972 HERGESTELLT
    TCP 192.168.2.67:17500 CABALZAR-NOTE:55239 HERGESTELLT
    TCP 192.168.2.67:17500 Eisbaer-PC:56719 HERGESTELLT
    TCP 192.168.2.67:17500 EISBAER-PC:57626 HERGESTELLT
    TCP 192.168.2.67:49419 157.55.236.63:https HERGESTELLT
    TCP 192.168.2.67:49455 sjc-not17:http HERGESTELLT
    TCP 192.168.2.67:49552 server15240:5938 HERGESTELLT
    TCP 192.168.2.67:49563 EISBAER-PC:17500 HERGESTELLT
    TCP 192.168.2.67:49567 CABALZAR-NOTE:17500 HERGESTELLT
    TCP 192.168.2.67:49572 ELVIRA-PC:17500 HERGESTELLT
    TCP 192.168.2.67:49655 v-d-1b:https SCHLIESSEN_WARTEN
    TCP 192.168.2.67:49659 fa-in-f125:5222 HERGESTELLT
    TCP 192.168.2.67:49673 server26:imap HERGESTELLT
    TCP 192.168.2.67:49705 st11p01st-courier132-bz:5223 HERGESTELLT
    TCP 192.168.2.67:49958 server3302:5938 HERGESTELLT
    TCP 192.168.2.67:50117 mil01s17-in-f9:https SCHLIESSEN_WARTEN
    TCP 192.168.2.67:50120 ELVIRA-PC:17500 HERGESTELLT
    TCP 192.168.2.67:50121 CABALZAR-NOTE:17500 HERGESTELLT
    TCP 192.168.2.67:50123 MSTYLE-PC:17500 HERGESTELLT
    TCP 192.168.2.67:50125 EISBAER-PC:17500 HERGESTELLT
    TCP 192.168.2.67:50394 MSTYLE-PC:17500 HERGESTELLT
    TCP 192.168.2.67:50395 mil01s16-in-f8:https SCHLIESSEN_WARTEN
    TCP 192.168.2.67:50641 mil01s16-in-f9:http HERGESTELLT
    TCP 192.168.2.67:50644 mil02s06-in-f22:https HERGESTELLT
    TCP 192.168.2.67:50651 wg-in-f125:5222 HERGESTELLT
    TCP 192.168.2.67:50655 mil01s17-in-f17:https HERGESTELLT
    TCP 192.168.2.67:50673 edge-star-ecmp-01-ash5:https HERGESTELLT
    TCP 192.168.2.67:50712 fa-in-f193:https HERGESTELLT
    TCP 192.168.2.67:50817 fa-in-f84:https HERGESTELLT
    TCP 192.168.2.67:50856 edge-star-ecmp-01-ash5:http HERGESTELLT
    TCP 192.168.2.67:50857 mil02s06-in-f14:https HERGESTELLT
    TCP 192.168.2.67:50984 2.20.18.46:https HERGESTELLT
    TCP 192.168.2.67:50990 OCSP:http WARTEND
    TCP 192.168.2.67:50991 OCSP:http WARTEND
    TCP 192.168.2.67:51001 199.101.115.34:https WARTEND
    TCP 192.168.2.67:51014 OCSP:http HERGESTELLT
    TCP 192.168.2.67:51015 OCSP:http WARTEND
    TCP 192.168.2.67:51016 OCSP:http HERGESTELLT
    TCP 192.168.2.67:51017 mil02s06-in-f2:https HERGESTELLT
    TCP 192.168.2.67:51018 mil02s06-in-f2:https HERGESTELLT
    TCP 192.168.56.1:139 Mstyle-HP:0 ABHÖREN
    TCP [::]:80 Mstyle-HP:0 ABHÖREN
    TCP [::]:135 Mstyle-HP:0 ABHÖREN
    TCP [::]:445 Mstyle-HP:0 ABHÖREN
    TCP [::]:554 Mstyle-HP:0 ABHÖREN
    TCP [::]:623 Mstyle-HP:0 ABHÖREN
    TCP [::]:1801 Mstyle-HP:0 ABHÖREN
    TCP [::]:1947 Mstyle-HP:0 ABHÖREN
    TCP [::]:2103 Mstyle-HP:0 ABHÖREN
    TCP [::]:2105 Mstyle-HP:0 ABHÖREN
    TCP [::]:2107 Mstyle-HP:0 ABHÖREN
    TCP [::]:2179 Mstyle-HP:0 ABHÖREN
    TCP [::]:2869 Mstyle-HP:0 ABHÖREN
    TCP [::]:3587 Mstyle-HP:0 ABHÖREN
    TCP [::]:5357 Mstyle-HP:0 ABHÖREN
    TCP [::]:9969 Mstyle-HP:0 ABHÖREN
    TCP [::]:10243 Mstyle-HP:0 ABHÖREN
    TCP [::]:16992 Mstyle-HP:0 ABHÖREN
    TCP [::]:49152 Mstyle-HP:0 ABHÖREN
    TCP [::]:49153 Mstyle-HP:0 ABHÖREN
    TCP [::]:49154 Mstyle-HP:0 ABHÖREN
    TCP [::]:49156 Mstyle-HP:0 ABHÖREN
    TCP [::]:49161 Mstyle-HP:0 ABHÖREN
    TCP [::]:49165 Mstyle-HP:0 ABHÖREN
    TCP [::]:49166 Mstyle-HP:0 ABHÖREN
    TCP [::]:49436 Mstyle-HP:0 ABHÖREN
    TCP [::]:55859 Mstyle-HP:0 ABHÖREN
    TCP [::1]:49190 Mstyle-HP:49192 HERGESTELLT
    TCP [::1]:49192 Mstyle-HP:49190 HERGESTELLT
    TCP [fe80::18a3:8eb0:2f91:7f7%80]:445 Mstyle-HP:49555 HERGESTELLT
    TCP [fe80::18a3:8eb0:2f91:7f7%80]:49555 Mstyle-HP:microsoft-ds HERGESTELL
    T
    UDP 0.0.0.0:427 *:*
    UDP 0.0.0.0:500 *:*
    UDP 0.0.0.0:1900 *:*
    UDP 0.0.0.0:1947 *:*
    UDP 0.0.0.0:3702 *:*
    UDP 0.0.0.0:4500 *:*
    UDP 0.0.0.0:5004 *:*
    UDP 0.0.0.0:5005 *:*
    UDP 0.0.0.0:5350 *:*
    UDP 0.0.0.0:17500 *:*
    UDP 0.0.0.0:49217 *:*
    UDP 0.0.0.0:54596 *:*
    UDP 0.0.0.0:54790 *:*
    UDP 0.0.0.0:54925 *:*
    UDP 0.0.0.0:55338 *:*
    UDP 0.0.0.0:56348 *:*
    UDP 0.0.0.0:57514 *:*
    UDP 0.0.0.0:57702 *:*
    UDP 0.0.0.0:58112 *:*
    UDP 0.0.0.0:58862 *:*
    UDP 0.0.0.0:59371 *:*
    UDP 0.0.0.0:59755 *:*
    UDP 0.0.0.0:60343 *:*
    UDP 0.0.0.0:61320 *:*
    UDP 0.0.0.0:62209 *:*
    UDP 0.0.0.0:62541 *:*
    UDP 0.0.0.0:63648 *:*
    UDP 0.0.0.0:64350 *:*
    UDP 0.0.0.0:65028 *:*
    UDP 127.0.0.1:1900 *:*
    UDP 127.0.0.1:56242 *:*
    UDP 127.0.0.1:57153 *:*
    UDP 127.0.0.1:57154 *:*
    UDP 127.0.0.1:57673 *:*
    UDP 127.0.0.1:57674 *:*
    UDP 127.0.0.1:57700 *:*
    UDP 127.0.0.1:57701 *:*
    UDP 127.0.0.1:57704 *:*
    UDP 127.0.0.1:57713 *:*
    UDP 127.0.0.1:59743 *:*
    UDP 127.0.0.1:59744 *:*
    UDP 127.0.0.1:60854 *:*
    UDP 127.0.0.1:62791 *:*
    UDP 127.0.0.1:63328 *:*
    UDP 127.0.0.1:64912 *:*
    UDP 127.0.0.1:64913 *:*
    UDP 127.0.0.1:65027 *:*
    UDP 192.168.2.67:137 *:*
    UDP 192.168.2.67:138 *:*
    UDP 192.168.2.67:427 *:*
    UDP 192.168.2.67:1900 *:*
    UDP 192.168.2.67:3671 *:*
    UDP 192.168.2.67:5353 *:*
    UDP 192.168.2.67:65025 *:*
    UDP 192.168.56.1:137 *:*
    UDP 192.168.56.1:138 *:*
    UDP 192.168.56.1:427 *:*
    UDP 192.168.56.1:1900 *:*
    UDP 192.168.56.1:3671 *:*
    UDP 192.168.56.1:5353 *:*
    UDP 192.168.56.1:65026 *:*
    UDP [::]:500 *:*
    UDP [::]:1947 *:*
    UDP [::]:3540 *:*
    UDP [::]:3702 *:*
    UDP [::]:3702 *:*
    UDP [::]:3702 *:*
    UDP [::]:3702 *:*
    UDP [::]:3702 *:*
    UDP [::]:3702 *:*
    UDP [::]:4500 *:*
    UDP [::]:5004 *:*
    UDP [::]:5005 *:*
    UDP [::]:49218 *:*
    UDP [::]:50393 *:*
    UDP [::]:57703 *:*
    UDP [::]:62210 *:*
    UDP [::]:65029 *:*
    UDP [::1]:1900 *:*
    UDP [::1]:5353 *:*
    UDP [::1]:65024 *:*
    UDP [fe80::18a3:8eb0:2f91:7f7%80]:546 *:*
    UDP [fe80::18a3:8eb0:2f91:7f7%80]:1900 *:*
    UDP [fe80::18a3:8eb0:2f91:7f7%80]:65022 *:*
    UDP [fe80::540c:5476:3afd:ceab%69]:546 *:*
    UDP [fe80::540c:5476:3afd:ceab%69]:1900 *:*
    UDP [fe80::540c:5476:3afd:ceab%69]:65023 *:*
    Bitte um Hilfe
    Besten Dank
  • flaery
    konnte jemand unter Windows mit C# erfolgreich auf den eibd zugreifen?
    Ich versuche das jetzt schon eine ganze Weile und komme nicht weiter.
    Eingebunden habe ich die EibConnection-0.0.3.cs und über EIBConnection bekomme ich auch eine Verbindung zum eibd. Was nicht funktioniert ist z.B. das senden eines Telegramms für Licht an oder aus.
    Im TraceLevel 5 vom eibd sehe ich nichts ankommen, aber über tcpdump sehe ich das was empfangen wurde.
    Kann mir jemand helfen?
    Danke und Gruß
    Flo
  • mkoegler
    1) EIBD kann nur IPv4
    2) Read-Flage beim Gruppenobjekt in der ETS gesetzt?
  • Rudolf
    hi,
    ist hier mal einer weiter gekommen mit c#? bekomme keine verbindung
    Schau dir den Konstruktor der Klasse an:
    public EIBConnection (String host): this (host, 6720) { }
    Da gibst du entweder localhost oder IP/Name vom wiregate ein.
    Einzig eibd muss mit dem Parameter -i gestartet sein.
    hier komme ich nicht weiter, da ich hier schon keine verbindung zum "server" bekomme. Egal ob ich die localhost oder 127.0.0.1 oder vom Gira router eingebe, es kommt immer "Es wurde eine Adresse verwendet, die mit dem angeforderten Protokoll nicht kompatibel ist [fe80::a91b:e168:be15:9b4%10]:6720" auch mit einem anderen Port.
    Starte ich den eibd auf der konsole und gebe schalt befehle über die konsole ab geht es.
    P.S hab noch das phänomen das wenn ich von pc einen gruppenadrese schalte kann ich den status dann nicht abfragen. das gleiche hab ich auch wenn ich das falcon sdk nutze. wenn ich jetzt aber z.B schalter am bus direkt setzt (z.B über eine binärkontakt) dann kann ich den status abfragen. habe einen testaufbau mit einer lampe an einen schaltaktor einen binäraktor mit magnetschalter. schalte ich die lampe über die software kann ich den status nicht abfragen schalte ich die lampe über den magnetschlater (hardware seitig) kann ich denn dann über die software den status abfragen. Hat das zufällig auch jemand?
    gruss rudolf
  • division
    Also bei mir funktionieren die Demoprogramme alle nicht.
    Egal welches ich davon aufrufe, passiert einfach nix.
    Keine Meldung zu Syntaxfehler oder Wie die Eingabe zu machen wäre. Einfach garnix.
    Egal.... werde mich dann mal an die C# Classe machen.
  • division
    Zitat von do13 Beitrag anzeigen
    Du brauchst im Prinzip nur #include "eibclient.h" und dann stehen dir die ganzen eibd Funktionen zur Verfügung. (Zumindest unter Linux)
    Hmmmm sehr spannend.... hätte ich mir schon lange man angucken sollen dieses SDK.
    Und unter Windows? Da müsste man diese "Tools" doch auch compiliert bekommen..... wie Groupswrite oder? Also jetzt nativ und nicht über Cygwin?!?!
  • do13
    Zitat von division Beitrag anzeigen
    Sehe ich das richtig, das du in deinem Quellcode mit einem eibd wo auch immer der läuft sprichst?
    Klar.
    Schau dir am besten im eibd die example Programme an:
    SourceForge - bcusdk/bcusdk/tree - eibd/examples/
    Z.Bsp. den vbusmonitor:
    SourceForge - bcusdk/bcusdk/blob - eibd/examples/vbusmonitor2.c
  • division
    Ein paar Sachen emuliert und einen erweiteren Busmonitor (so wie ich ihn brauchte)
    Ahhh sehr interesant......
    Habe leider gestern keine Zeit mehr gehabt das noch zu testen, schaffe das aber hoffentlich heute Abend.
    Würdest du eventuell ein paar Sourcen in c oder c++ zur verfügung stellen? Oder mir per Mail schicken? Wäre das sehr interessiert dran.... an sowas lernt man immer am besten. (Framework sparen wär da sehr interessant.... so auf einem Intel Atom tut sich .Net 4 schon arg schwer....)
  • do13
    Warum bist du bei c++ geblieben? Gibts da spezielle gründe? .NET macht einem bei vielem das Leben schon leichter.
    Es passte halt mehr zu dem Rest. D.h. ich konnte vorhandene Routinen in C direkt aufrufen.
    Außerdem ist C/C++ schon ressourcensparender. Da spare ich mit auf einem Embedded System das ganze Framework.
    Aber wir wollen jetzt keinen Glaubenskrieg führen....
    Was hasst du da programmiert im bezug auf eibd und KNX?
