KNX Schneider Mulltitouch Pro MTN6215-0310
    I have a multitouch pro MTN6215-0310, upon first initial power up the screen displays ETS address as well as other information then changed to device not configured.
    So on ETS, I am trying to send the application from the manufactures list for this device and after sending the application it comes up with download failed and then screen is blank and even after another power up it is blank. On ETS i can still see the device, change address ect.. just unable to send the application. I then bought another on which has done the exact same thing..
    Having a closer look in the manufactures list for this device there seems to be a few options which i then noticed for the same MTN6215-0310 there is push button options but also a touch screen option 1.4 and 1.1, (in device info it says 1.1) so would it be an issue if the wrong one was sent causing the screen to not display anything? I have tried to unload application and send the one i thought it may be but still fails so i am a bit stuck and wondered if anyone can offer some help as now have two of these units both not showing anything.
    If i plug into the screen the micro usb i can see the display which shows in red, ERROR during test, Error code :0008 SW Ver.:26, if i power down taking the knx connection on and then plug in the micro USB it comes up with MCS USB mode,
    Anyone have any ideas?
    Thanks
    So managed to sort the issue, for some reason if running the application through ETS5 is works and the download sends with no issues, but on ETS6 it fails..
