Problem mit ETS4 ABB Plugin
    KNX/EIB Problem mit ETS4 ABB Plugin
    Entschuldigen Sie dass ich auf English screibt... ich verstehe gut, aber finde es schwierier auf Deutsch zu screiben...
    After having imported the knxprod file for ABB SD/S x.16.1 (Switch-/Dim Actuator) updated 2011-10-12, I can no longer open up the parameter dialog for any of my ABB devices that opens the dialog in a separate window. The ETS4 will give me the error message "An internal error occured. Specified cast is not valid". My guess is that this updated included a new version of some of the dll-files used by some of the ABB devices.
    I will get this message also for other devices that opens the parameters in a separate window, e.g. the UK/S 32.2.
    Does anyone know of a way to "downgrade" a plugin? Or preferable a real solution to the problems itself (which has been reported to ABB).
    Patrik
    Thanks to ABB support, problem has now been solved. In case someone else experiences the same problem, here is more information about the issue:
    This is an Problem with the ETS4, Version 4.0.4, 4.0.5 and 4.0.6.
    Here is the official statement from the Konnex Association:
    Dear customer, we have analyzed the root cause of the problem with (not) showing the dialog of some ABB devices. We will solve the problem as fast as possible permanently in a next ETS4 update. For the time being there is an easy „Workaround „to solve” the problem on your current ETS4 installation. Your projects will be not touched!
    1. Please navigate to the folder %programdata%\knx\Compatibility
    2. Delete there the file PluginInformation.xml
    3. Restart the ETS4, the parameter dialog works from now on.
    Patrik
