Hello,
Is there a way to reboot/reset a KNX device using the Gira Homeserver (using Send IP/KNX Telegrams) or using an LBS?
Probably this has already been asked many times, but after multiple searches here and on Google I couln't find it.
I know that it isn't good knowledge to reboot a device... why should you? Well, I have a Theben OT (OpenTherm) Gateway and I have seen it multiple times being 'stuck' when the gas heater (a NEFIT/Bosch device) was giving an error code for a few hours (like: Please, fill water, pressure to low). I don't want to turn down the power of the whole KNX system or unplug the OpenTherm gateway in those cases. I just want a button 'restart OpenTherm Gateway' in the Quadclient
- I didn't find a Baustein for it.
- I also tried using the Homeserver 'Send IP/KNX Telegrams' option, but that method can only do 'GroupValueWrite' to a GroupAddress. I need a 'T_ACK (S=1)' and 'RESTART (S=2)' to be send to a Physical Address.
