Schäm ...
Deshalb hatte ich ja gesagt: Nur wenn Makki nix dagegen hat.
Ich tu's nie wieder (solche Sachen verraten ...)
[B]Name [/B]AUERSessionID [B]Wert [/B]******* [B]Host [/B]172.26.193.147 [B]Pfad [/B]/ [B]Sicher [/B]Nein [B]Gültig [/B]bisSitzungsende [B]Name [/B]******* [B]Wert [/B]user-name [B]Host [/B]172.26.193.147 [B]Pfad [/B]/ [B]Sicher [/B]Nein [B]Gültig [/B]bisSitzungsende
my $json_data = decode_json($listges_data); # hash fuer die Daten
### Plugin Array zerlegen $plugin_info{$plugname.'_cycle'} = 3600; # alle x sekunden #my $baseurl = 'http://172.26.193.148/test/statics/'; #my $listgesprurl = 'auerweb_page_listgespr.php?offset=0'; my $baseurl = 'http://172.26.193.147/'; my $listgesprurl = 'page_listgespr_state?offset=0'; my $debug = 0; ### ENDE Definitionen #return; ### ab hier nichts verändern my $date; my $time; my $call_length; my $ex_number; my $ex_name; my $direction; my $success; use JSON::XS; use HTTP::Cookies; use XML::Writer; use IO; use LWP::Simple; use HTML::Entities; use utf8; #use strict; use warnings; #use File::Find; #use XML::RSS; #use HTML::TreeBuilder; #use Getopt::Long; # Abfrage my $url = $baseurl.$listgesprurl; my $listges_data = get($url); #$listges_data = $string_data; #decode_entities($listges_data); #encode_entities($listges_data); #return $url; #return $listges_data; if ($listges_data eq undef) { return 'HTTP failed.'; } #$object = JSON::XS->new->decode (decode "UTF-16BE", $jsontext); #Daten decoden $listges_data= encode ('utf8', $listges_data->{response}); my $json_data = decode_json($listges_data); # hash fuer die Daten #my $json_data = from_json($listges_data); # hash fuer die Daten my $data_xml= new IO::File(">/var/www/AW/output.xml"); my $data_rss= new IO::File(">/var/www/AW/rss.xml"); my $writer_xml = new XML::Writer (OUTPUT => $data_xml, NEWLINES => 0); $writer_xml->xmlDecl('UTF-8'); $writer_xml->startTag ("calls"); #$write_xml-> my $writer_rss = new XML::Writer (OUTPUT => $data_rss, DATA_MODE => 1, DATA_INDENT=>2); $writer_rss->xmlDecl('UTF-8'); $writer_rss->startTag("rss" ,"version"=>"2.0", "xml:base"=>"http://172.26.193.148/visu", "xmlns:dc"=>"http://purl.org/dc/elements/1.1/"); $writer_rss->startTag ("channel"); $writer_rss->dataElement( "title", "Anrufliste" ); foreach my $call (@{$json_data}) { $date = @{$call}[1]; $time = @{$call}[2]; $call_length = @{$call}[3]; $ex_number = @{$call}[5]; $ex_name = @{$call}[6]; $direction = @{$call}[14]; $success = @{$call}[15]; if ($ex_name eq "") { $ex_name = "Unbekannt"; } $writer_xml->emptyTag ("call",'date' => $date, 'time'=> $time,'length' => $call_length,'ex-number' => $ex_number,'ex-name' => $ex_name,'direction' => $direction,'success' => $success); #rss $writer_rss->startTag ("item"); if ($success eq "vergebl.") { $writer_rss->dataElement( "title", "Verpasster Anruf von $ex_name ($ex_number)" ); $writer_rss->dataElement( "description", "Verpasster Anruf von $ex_name ($ex_number) um $time am $date" ); } else { $writer_rss->dataElement( "title", "Anruf von $ex_name ($ex_number)" ); $writer_rss->dataElement( "description", "Anruf von $ex_name ($ex_number) um $time am $date" ); } #$writer_rss->emptyTag ("call",'date' => @{$call}[1], 'time'=> @{$call}[2],'length' => @{$call}[3],'ex-number' => @{$call}[5],'ex-name' => @{$call}[6],'direction' => @{$call}[14],'success' => @{$call}[15]); $writer_rss->endTag("item"); } $writer_xml->endTag ("calls"); $writer_rss->endTag ("channel");
