- √ - Universal Zeitshalturen -> Logic module
    I am a HS virgin with some problems. Have now come to a level where I will try to control my heating. I use a normal thermostate and use its output to start the central heating. Now I would like to combine this in a logic module where the AND logic would exist out of Thermostate output and Zeitschaltur output. This would give me the chance to set the times/days at which the heating should work.
    So how do I get a zeitschaltur output into a in-port of a logic module?
    Define a new "internes Kommunikationsobjekt" as 1-bit value that is switched by the "Schaltuhr". Now you can use this object as an input value for your AND-logic.
      Thanks, your answer made me suddenly understand the whole Logic programming system. Thus I will create K-objects internally for the use in all other functions. Very smart... .
      Dirk
