Entering a specific date GIRA X1 Logic
    X1 Entering a specific date GIRA X1 Logic
    Is there a way to enter a specific date in the GIRA X1 visualisation so that it can be compared using the date/time logic block?
    The idea is that when you leave for a holdiay that you can already enter the date of return. The holiday mode of the house will then be activated but it will stop automatically at the given date.
    Is there a way to achieve this?
    Thanks!
    Unfortunately there is no element available for text value entry or date/time value entry. So the only -- somewhat cryptic -- way to enter this would probably be a "32-bit Wertgeber ohne Vorzeichen" (don't know how it is called in english). The number could be in the format DDMMYY, to be converted to a DateTime object by an Expression Calculator. The result -- or in case of an invalid entry, an error -- could be visualized in a text status display.
    Zuletzt geändert von hyman; 12.02.2022, 17:22.
      Not a solution for the X1, but the MDT Glasbedienzentrale (GBZ) has a quite easy way for entering times of holiday at the display. It provides the information on KNX.
      I use also both X1 and GBZ.
      Gruß Bernhard
