Steuereinheit 1–10 V
    KNX/EIB Steuereinheit 1–10 V
    I have a Gira 101700 Steuereinheit.
    When I send a brightness value of 100% I measure just 3,279V
    I was expecting 10V!
    If I connect a 10K resistor to the output the voltage drops to 0,1236V
    My KNX bus power supply is a 640mA unit and the total current draw is about 330mA.
    Is that normal behaviour?
    Dont do Anything like that please!!!
    The Analogue Output 1-10v is a passive device. You should connect it to the Dynamic ballast of a Illumination Tube.
    You will Never get 10v if you dont do it like that. And this device is just made for this Case.
    Best Regards Peter
    Tapko Technologies GmbH (Sales DACH) - www.tapko.de
    SBS GmbH on FB - PeterPan on FB
      Thanks Peter.
      So there's no easy way to get a 0-10V output from this device?
      I wanted to use it to control the heating system which has a 0-10V interface.
        You can use this:
        Brumberg Leuchten - Licht seit Generationen
        Gruß Stephan
          Ok, so the Gira 101700 Steuereinheit can be connected to the "Brumberg passiv-aktiv Wandler 1-10 V" and that unit will then provide the 1-10V?
            Hello..
            "can be"! But it is better to use an analogue output that brings you the correct 0-10V signal active. There are alot on the market from different companies.
            Best Regards
            peter
              Danke.
              The Brumberg unit is only €29 (single channel) while an analogue 0-10V unit will cost me way more I guess.
              On the other hand I could still use the 101700 as 3-channel switch actuator
              Have been looking for quite a while now for a single-channel analogue 0-10V output device but cannot find it.
              It seems to be it's either 4-channel or it is a non-analogue one like the 101700.
              Gira seems to have none.
                Hello..
                single Unit is not on the market.
                Greez
                Peter
                  Would you know a multi channel partnumber?
                  Found 1 from Gira, the 102200 but at €290 excluding the required 24V power supply rather expensive...
                    Life is hard :-)
                    Best Regards
                    Peter
                      And on top of it expensive as well
                        Don't think long. Girls are more expensive! :-)
                          Would THIS unit be the correct one?
                            No..
                            This one: http://www.knx-gebaeudesysteme.de/st...05066D0105.PDF
                              Thanks all but it looks like I found an even better solution.
                              The Theben KNX-OT-Box.
                              It is an interface between KNX and OpenTherm which is a language my heater understands.
                              The price is about the same as an active 1-10V unit and it could give me much more information about the heater system.
