Radio roller shutter motor for connection to the ABB SA/H roller shutter actuator
Hello. Is it possible to connect the roller shutter actuator in this case? As you can see in the manual, the roller shutter motor is constantly supplied with voltage.Hello. A connection of a roller shutter actuator is possible in this case. As you can see in the manual, the roller shutter motor is constantly supplied with voltage. The manufacturer of this engine was not able to answer that question and I don't want to burn the engine or the actor. Regards. Darek.
This gallery has 1 photos.
