UP Hybrid device: 1 output, 1 input
    KNX/EIB UP Hybrid device: 1 output, 1 input
    I'm looking for a Hybrid device, UP
    1 output (500mA)
    1 binary input
    I found the Hager TXB202A, but it has 2 outputs.
    Thanks for any hint
    Maybe this thing doesn't exist ?
    I'll have to use 2 devices: a UP binary input and a UP actuator, but they will not fit in the box
      Hi Warichet,
      maybe something like this?
      KNX Schaltaktor 2-fach UP mit Nebenst.Anschl. 2132.6 UP - EIBMARKT GmbH Technisches Gebäudemanagement
      regards
      Marcel
      seit: 11'08 KNX / 04'09 HS3 / 12'09 WG mit 21 Temp & 4 Feuchtesensoren / 10'10 Enocean mit 15 Fenstergriffe Hoppe / 02'11 MBus2Serial Gas-Wasserzähler
      HS3: 99% / VISU: PV 99%, iPad 99%
      60 Akt. Linie1 / 14 Akt. Linie2
        Hi Marcel,
        Looks good, indeed
        The doc says
        Belegung per Software einstellbar:
        So, I've to download the application and have a close look.
        Thank you for the tip
