- √ - Brightness value 0 issue
    Dear,
    1) When I issue a brightness value 0 to a device, this works fine. The light goes out.
    2) When I immediately after that try to switch the light on via a switch I've to push twice. It is like the switch is not aware this light was off.
    How to resolve this?
    Best regards,
    Tim
    You need to define a status GA which is send by the aktor. This GA you need to add to the switch (in addition to the switching GA). The switch will listen to the status GA and send the good value next time you press the button.
    BR
    Marc
      many thanks, indeed this was the trick.
      I added the feedback led, but forgot the initial switch.
