GIRA HS3, Client 19
    GIRA HS3, Client 19
    Hello, community)
    I've got some very old GIRA HS3. Last week I've got a problem with it: they failed due to a breakdown of the power supply and video chip. This time i solved the problem using soldering iron. But I expect such problems with all old HS3. So I wondering, maybe I can use micro PC instead of HS3? I think, that I can replace SSD from HS3 to another device and connect it to knx via USB or IP-router.
    Also, I've got the same problem with GIRA Control Client 19. It's very old device and that's why I'm looking for something to use instead Client. Maybe Wall-mount PC, because the mounting box is already installed.
