Philips HUE + KNX in a single Node-Red's node. New from KNX-Ultimate.
    Wow! That was a fast answer.
    I'm speechless
    Perfectly fine to both points 👍
    Keep up the good work. I believe a lot of people are really grateful for it.
    I certainly am.
      Hi Banzai
      node-red-contrib-knx-ultimate@2.1.57 is out and should have fixed the issues with the brighness value.
      For the other things, i've opened an issue on github for you, so i can remember what to do.
      Zuletzt geändert von TheMax74; 21.10.2023, 13:12.
        Hi Banzai
        node-red-contrib-knx-ultimate@2.1.59 is out with a color picker and a color getter.
        Hope this helps.
        Cheers!
          Hi
          a massive update in the DIM/Tunable White function of HUE Light has been rolled out.
          Version 2.2.1 is out now.
            Hi Max
            thank you for all the work you put in knx Ultimate. Could you please add absolute Colortemperature DPT 7.600 to the TW settings ?
              Yes.
                Hi ,
                DPT 7600 already exists. What is "TW"?
                  Tunable White the only Option is Percentage 0-100 and dimming.
                    Ah, ok :-)
                      deleted
                      Zuletzt geändert von TheMax74; 02.11.2023, 12:24.
                        delete
                        Zuletzt geändert von TheMax74; 02.11.2023, 13:41.
                          Hi
                          Can you please tell me the kelvin scale of the DPT 7.600? Is it 1500 to 8000k ?
                            It depends on the actuator (its parameters for most - maybe there are fixed ones too). Some report 0 when off.
                              V. 2.2.8 is out. Can you test it? Thanks.
                                Hi Max, unfortunaly my Raspberry or my SD Card is broken. I cant find any Lights after update to your latest Version. I configured a new Hue Gateway same issue.
                                4 Nov 09:33:34 - [error] TypeError: Cannot read properties of undefined (reading 'isConnected')
                                    at /home/lars/.node-red/node_modules/node-red-contrib-knx-ultimate/nodes/hue-config.js:129:47
                                    at Timeout._onTimeout (/home/lars/.node-red/node_modules/node-red-contrib-knx-ultimate/nodes/hue-config.js:133:11)
                                    at listOnTimeout (node:internal/timers:569:17)
                                    at process.processTimers (node:internal/timers:512:7)
                                My Linux skills are very basic so i dont know how to fix this. One time it was a very slow SD card so the Pi went often in Timeout so it was not usable. I will buy a new micro sd and test with a clean install.
