Logic Bausteine Dokus
    HS/FS Logic Bausteine Dokus
    Hi!
    First, excuse my English message, I will try to translate in german with google translate.
    I'm looking for a instruction sheet about how to program my own logic modules, I'm trying to program myself a module but don't understand the language.
    I've searched but didn't find anything. Maybe anyone can point me to the right direction?
    Many thanks in advance!
    Regards
    GERMAN (Google Translate)
    Hallo!
    Ich suche nach einer Anleitung dazu, wie meine eigene Logik Module programmieren suchen, ich versuche mich selbst zu programmieren, ein Modul, aber nicht die Sprache verstehen.
    Ich habe gesucht aber nichts gefunden. Vielleicht kann jemand zeigen Sie mir die richtige Richtung?
    Vielen Dank im Voraus!
    Some years ago, I wrote this very simple How-To:
    HowTo: Logikbaustein erstellen - HS/FS - Lexikon - KNX-User-Forum
      Many thanks MatthiasS!
      Seeing the document, I have a little doubt with the syntax as the translator mess up a little..
      5000|"Text"|Remanent(1/0)|Anz.Eingänge|.n.|Anzahl Ausgänge|.n.|.n.
      5001|Anzahl Eingänge|Ausgänge|Offset|Speicher|Berechnung bei Start
      5002|Index Eingang|Default Wert|0=numerisch 1=alphanummerisch
      5003|Speicher|Initwert|Remanent
      5004|ausgang|Initwert|runden binär (0/1)|typ (1-send/2-sbc)|0=numerisch 1=alphanummerisch
      5012|abbruch bei bed. (0/1)|bedingung|formel|zeit|pin-ausgang|pin-offset|pin-speicher|pin-neg.ausgang
      Please, can you give me some more details about syntax definitions and types, maybe in English?
      Many thanks again for your reply!!
      Best regards.
      Ps. By the way, I'll keep reading the document..
        I'll be back at home on Sunday, then I will translate
          Hi MatthiasS
          I have translated the document to spanish, by the way.. deep reading with translator appears to be self explanatory.
          Now, I have developed three modules and they're working
          Int to hex converter with string output
          16bits to 2 byte converter
          Checksum calculator
          This checksum calculator is the main reason for developing my own modules.
          I have seen in DACOM document, that the modules supports only importing of four libraries (wrandom, string, math and time) but appears to support more python libraries, maybe you have a complete list of supported libraries?
          Regards!
            Congratulations
            Sorry, there is no list. But many of them will work.
