Hi, I have latest firmware 2.8.869, after I've applied it to my project web requests 3.0.5 node stupped working after I updated.
It seems to only send requests when I do simulation.
Is there a better up to date HTTP request node? I'm not sure how to debug that.
Ok, looks like I've found the cause, I had non-escaped quotes in the payload and something changes in the firmware where simulation worked but not real requests and the software expected escaped quotes, tested in both Kai's and Daniel request modules:
{"type": "note", "title": "Brama", "body": "Brama GARAŻOWA jest otwarta", "channel_tag":"removed"}
should become:
and now its working again, I wonder if this is firmware bug?
