- √ - Transfergatter
    I'm unable to use the Transfergatter. The Experte complains about Dataformat
    The doc says
    Datentyp und Wert des Eingangstelegramms werden nicht verändert.
    OK, but does it work for a 14Byte text ?
    I'm trying to use a logic to block/enable a 14Byte text data.
    The Sperre doesn't do it. Maybe the Transfergatter ?
    Thank you for any tip.
    No (Answering my own question)
    I found the module Transfergatter back in logik.dat and modified it to allow for text. Works now.
      take a look at the modul "Eingangswahlschalter (Text)".
      It allows to switch the input-text to 8 outputs.
      Gruß Christian
        Hi Christian,
        Thank you for the hint.
        Yes, I did look at it, but it's not exactly what I want.
        In fact, I needed a "Sperre" for text, that is: the input text will pass through or be blocked depending on a binary input variable.
        In my case, I display the IP address of the HS visitors "guest" only if they are coming from outside my private LAN.
        Works now :-)
          Hi Warichet!
          Could you be so kind to send me the modification of the transfergatter to work with text?
          Maybee you could just tell us the modified Code between the CODE][/CODE tags
          EPIX
            Zitat von EPIX Beitrag anzeigen
            Could you be so kind to send me the modification of the transfergatter to work with text? [/CODE tags
            No problem.
            I'll have a look at it tonight.
