Ballasts not discovered by Dali Gateway (Eelectron IC00P02DAL)
    DALI Ballasts not discovered by Dali Gateway (Eelectron IC00P02DAL)
    Hi everybody,
    I have some issues with my Dali gateway and I don't know how to sort it out. The Eelectron Dali Gateway doesn't discover two of the five ballast attached to the Dali bus. It did initially, infact I was able to successfully test the attached leds, but after saving the configuration, in ETS the group obiects for these two leds are missing (the others work just fine) and if I re-run the ballast discover into the ETS plugin, the missing ones don't show up.
    Does anybody have a suggestion?
    I was thinking to reset the Gateway, but the technical docs are pretty unclear and I don't know if this can be done and how. Any suggestion on this regard?
    I was also thinking about decommissioning the DALI gateway from ETS, change its address and start over with the configuration. Any suggestion on how to do it (never done before)?
    Thx a lot for your support
    Aldo​
