Dann wars dass nicht...
Ich such weiter
# The loopback network interface auto lo eth0 iface lo inet loopback allow-hotplug eth0 # The primary network interface iface eth0 inet dhcp
root@wiregate619:/var/run# lshal error: dbus_bus_get: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mar 9 20:19:08 wiregate619 hald[11259]: 20:19:08.803 [E] hald_dbus.c:5747: dbus_bus_get(): Did not receive a reply. Possible causes include: the remote application di$ Mar 9 20:19:13 wiregate619 hald[11342]: 20:19:13.644 [I] hald.c:669: hal 0.5.11 Mar 9 20:19:13 wiregate619 hald[11342]: 20:19:13.645 [I] hald.c:678: Will daemonize Mar 9 20:19:13 wiregate619 hald[11342]: 20:19:13.645 [I] hald.c:679: Becoming a daemon Mar 9 20:19:13 wiregate619 hald[11343]: 20:19:13.649 [I] hald_dbus.c:5381: local server is listening at unix:abstract=/var/run/hald/dbus-w862zEAkRn,guid=f2d4468449b5a$ Mar 9 20:19:13 wiregate619 hald[11343]: 20:19:13.653 [E] hald_dbus.c:5747: dbus_bus_get(): Did not receive a reply. Possible causes include: the remote application di$ Mar 9 20:20:05 wiregate619 hald[12222]: 20:20:05.330 [I] hald.c:669: hal 0.5.11 Mar 9 20:20:05 wiregate619 hald[12222]: 20:20:05.331 [I] hald.c:678: Will daemonize Mar 9 20:20:05 wiregate619 hald[12222]: 20:20:05.332 [I] hald.c:679: Becoming a daemon Mar 9 20:20:05 wiregate619 hald[12223]: 20:20:05.334 [I] hald_dbus.c:5381: local server is listening at unix:abstract=/var/run/hald/dbus-twOxrE1F19,guid=e3898674f50e5$ Mar 9 20:20:05 wiregate619 hald[12223]: 20:20:05.337 [E] hald_dbus.c:5747: dbus_bus_get(): Did not receive a reply. Possible causes include: the remote application di$
> apt-get install hal --reinstall -y Paketlisten werden gelesen... Abhängigkeitsbaum wird aufgebaut... Lese Status-Informationen ein... Die folgenden zusätzlichen Pakete werden installiert: hal-info libdirectfb-extra libhal-storage1 libsmbios-bin libsmbios2 libsplashy1 libx86-1 pm-utils powermgmt-base radeontool uswsusp vbetool Vorgeschlagene Pakete: gnome-device-manager libsmbios-doc cpufrequtils splashy Die folgenden NEUEN Pakete werden installiert: hal hal-info libdirectfb-extra libhal-storage1 libsmbios-bin libsmbios2 libsplashy1 libx86-1 pm-utils powermgmt-base radeontool uswsusp vbetool debconf: Schiebe die Paket-Konfiguration auf, da apt-utils nicht installiert ist 0 aktualisiert, 13 neu installiert, 0 zu entfernen und 0 nicht aktualisiert. Es müssen noch 0B von 1963kB an Archiven heruntergeladen werden. Nach dieser Operation werden 5132kB Plattenplatz zusätzlich benutzt. Wähle vormals abgewähltes Paket libhal-storage1. (Lese Datenbank ... 70615 Dateien und Verzeichnisse sind derzeit installiert.) Entpacke libhal-storage1 (aus .../libhal-storage1_0.5.11-8_i386.deb) ... Wähle vormals abgewähltes Paket libsmbios2. Entpacke libsmbios2 (aus .../libsmbios2_2.0.3.dfsg-1_i386.deb) ... Wähle vormals abgewähltes Paket hal-info. Entpacke hal-info (aus .../hal-info_20080508+git20080601-1_all.deb) ... Wähle vormals abgewähltes Paket powermgmt-base. Entpacke powermgmt-base (aus .../powermgmt-base_1.30+nmu1_i386.deb) ... Wähle vormals abgewähltes Paket pm-utils. Entpacke pm-utils (aus .../pm-utils_1.1.2.4-1_all.deb) ... Wähle vormals abgewähltes Paket hal. Entpacke hal (aus .../archives/hal_0.5.11-8_i386.deb) ... Wähle vormals abgewähltes Paket libdirectfb-extra. Entpacke libdirectfb-extra (aus .../libdirectfb-extra_1.0.1-11_i386.deb) ... Wähle vormals abgewähltes Paket libsmbios-bin. Entpacke libsmbios-bin (aus .../libsmbios-bin_2.0.3.dfsg-1_i386.deb) ... Wähle vormals abgewähltes Paket libsplashy1. Entpacke libsplashy1 (aus .../libsplashy1_0.3.13-3+lenny1_i386.deb) ... Wähle vormals abgewähltes Paket libx86-1. Entpacke libx86-1 (aus .../libx86-1_1.1+ds1-2_i386.deb) ... Wähle vormals abgewähltes Paket radeontool. Entpacke radeontool (aus .../radeontool_1.5-5_i386.deb) ... Wähle vormals abgewähltes Paket uswsusp. Entpacke uswsusp (aus .../uswsusp_0.7-1.2_i386.deb) ... Wähle vormals abgewähltes Paket vbetool. Entpacke vbetool (aus .../vbetool_1.0-3_i386.deb) ... Verarbeite Trigger für man-db ... /usr/bin/mandb: Der von Man benutzte Nutzer »man« existiert nicht Richte libhal-storage1 ein (0.5.11-8) ... Richte libsmbios2 ein (2.0.3.dfsg-1) ... Richte hal-info ein (20080508+git20080601-1) ... Richte powermgmt-base ein (1.30+nmu1) ... .udevdb or .udev presence implies active udev. Aborting MAKEDEV invocation. Richte pm-utils ein (1.1.2.4-1) ... Richte hal ein (0.5.11-8) ... Reloading system message bus config...Failed to open connection to system message bus: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken. invoke-rc.d: initscript dbus, action "force-reload" failed. Starting Hardware abstraction layer: haldinvoke-rc.d: initscript hal, action "start" failed. dpkg: Fehler beim Bearbeiten von hal (--configure): Unterprozess post-installation script gab den Fehlerwert 1 zurück Richte libdirectfb-extra ein (1.0.1-11) ... Richte libsmbios-bin ein (2.0.3.dfsg-1) ... Richte libsplashy1 ein (0.3.13-3+lenny1) ... Richte libx86-1 ein (1.1+ds1-2) ... Richte radeontool ein (1.5-5) ... Richte uswsusp ein (0.7-1.2) ... debconf: kann Frontend nicht initialisieren: Dialog debconf: (TERM ist nicht gesetzt, das Dialog-Frontend kann daher nicht verwendet werden.) debconf: greife zurück auf das Frontend: Readline Konfiguriere uswsusp -------------------- Kein geeigneter Swap-Bereich für Software-Suspend gefunden Um das System in den Ruhezustand versetzen zu können, benötigt uswsusp eine Swap-Partition oder -Datei, in die der Schnappschuss des Systems gespeichert wird. Dafür scheint kein solcher Platz vorhanden zu sein. Sie sollten eine Swap-Partition oder -Datei erstellen, falls möglich doppelt so groß wie der physische RAM des Systems. Führen Sie dann »dpkg-reconfigure uswsusp« aus oder bearbeiten Sie die Konfigurationsdatei manuell. Richte vbetool ein (1.0-3) ... Fehler traten auf beim Bearbeiten von: hal E: Sub-process /usr/bin/dpkg returned an error code (1)
Mar 9 15:00:38 wiregate619 hald[21712]: 15:00:38.630 [I] hald.c:669: hal 0.5.11 Mar 9 15:00:38 wiregate619 hald[21712]: 15:00:38.631 [I] hald.c:678: Will daemonize Mar 9 15:00:38 wiregate619 hald[21712]: 15:00:38.632 [I] hald.c:679: Becoming a daemon Mar 9 15:00:38 wiregate619 hald[21713]: 15:00:38.635 [I] hald_dbus.c:5381: local server is listening at unix:abstract=/var/run/hald/dbus-Ndw7fWJXEK,guid=4d239e13aaa6aea0fbf715624f5a0d06 Mar 9 15:00:38 wiregate619 hald[21713]: 15:00:38.645 [E] hald_dbus.c:5747: dbus_bus_get(): Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken. root@wiregate619:/etc# root@wiregate619:/etc# cd /var/run/hal/ root@wiregate619:/var/run/hal# ls root@wiregate619:/var/run/hal# cd /var/run/hald -bash: cd: /var/run/hald: Datei oder Verzeichnis nicht gefunden
