Hello,
I'm willing to install a street portal (Straßentor).
The portal is 115m from house, width: 4m, with 2 wings (Flügel) 2m, 95Kg each.
My first idea was to simply use a "Jalousienaktor" but by reading the forum, I understand there is a whole problematic around this topic.
First, I've to select the type of motor ad-hoc for this particular case.
Second, I want to integrate it with KNX.
I see 2 issues
1) open the portal, remote (from inside the house) when someone rings the door bel, hence the idea of a "Jalousienaktor" but I realize now that it is inadequate for security reasons. So I've to interact with the motor control box.
2) open the portal from inside the car while coming from the outside, via a radio remote control.
I've done a similar thing for the Hörmann garage door, but there I bought an optional box (UAP) to convert from radio to TP KNX. But here ?!?
The small side-door will be unlocked with a digicode.
Anyone wants to share a practical experience,
recommendation about the type of motor,
management of the feedback for the Visu,
a pointer to ad-hoc reading ?
It's impossible to download each document and study it, hence a recommendation for a similar case would be much appreciated.
NB: the portal is new (waiting since 6 years in the garage) the side walls and pilars have to be build. I'm at step zero: making plans and drawings, trying to do it right first time.
I see 2 issues
