Node Red: Warn KNX Ultimate GetResources HUE server Id is null
    Guten Tag,
    ich habe ein Problem mit Node Red und der KNX Ultimate Bibliothek.
    Ein KNX HUE Lampe ist angelegt, es steht immer Initializing, Please wait da.
    KNX_Lampe.png​
    Folgende Fehlermeldung finde ich im log:
    So ist meine Bridge konfiguriert, IP passt, Knopf an der Bridge wurde gedrückt.
    Hier kommen keine Hue Geräte rein.
    Hat jemand einen Tipp, was ich übersehe oder falsch mache?
    Mit der huemag Bibliothek läuft es.
    Danke
    Marek
    Hi
    please restart node-red and see if it works.
      Hello TheMax74,
      after reboot still the same.
      Marek
        Hi
        please update to the latest 3.0.1
        The hue devices should start showing up as soon as you start typing.
          I encountered this issue, too. I will try again with the latest update. Thank you for your great work!​
            Nothing changed with the 3.0.1
            Thanks
            Marek
              bad news from me either:
              The bridge ist found, but no devices available. Is the some way to get a more detailed error log?
                does the HUE HUB have a fixed IP?
                  ...and... have you tried restarting nodered?
                    Yes, fixed IP address and i restarted it.
                    It found the bridge after i pushed the connection button on it, but doesn´t shows me any devices.
                    Marek
                      Can you show me the node red’s log?
                      Try typing node-red-log -n 2000 in a terminal window.
                        Also..please upgrade to 3.0.2. It has more verbose log.
                          Thanks
                          Marek
                          There is no reason for not showing up the devices.
                          I need to view your node red log, please.
                            [info] 7/1/2024, 7:28:08 PM.110 User has been created on the Hue Bridge. The following username can be used to
                            authenticate with the Bridge and provide full local access to the Hue Bridge.
                            YOU SHOULD TREAT THIS LIKE A PASSWORD
                            [info] 7/1/2024, 7:28:08 PM.111 Hue Bridge User: tw72LsSfZtY2UgR3sfndzmrHSgXe70vPBVOH1O8H
                            [info] 7/1/2024, 7:28:08 PM.111 Hue Bridge User Client Key: 78AFCCAE4A271956C6031322FE60AD28
                            [info] 7/1/2024, 7:28:08 PM.112 ************************************************** *****************************
                            WARNING: You are using this library in an insecure way!
                            The Hue bridge supports HTTPS connections locally and it is highly recommended that you use an HTTPS
                            method to communicate with the bridge.
                            [info] 7/1/2024, 7:28:08 PM.202 Connected to Hue Bridge: Hue Bridge :: 192.168.2.49
                            1 Jul 19:29:04 - [warn] Warn KNXUltimateGetResourcesHUE serverId is null
                            1 Jul 19:29:06 - [warn] Warn KNXUltimateGetResourcesHUE serverId is null
                            1 Jul 19:31:27 - [info] Stopping flows
                            1 Jul 19:31:27 - [info] Stopped flows
                            1 Jul 19:31:27 - [info] Updated flows
                            1 Jul 19:31:27 - [info] Starting flows
                            [info] 7/1/2024, 7:31:27 PM.856 IP Protocol AUTO SET to Multicast, based on IP 224.0.23.12
                            1 Jul 19:31:27 - [info] KNX-Unsecure: connection to insecure interface/router using node KNX Gateway
                            [info] 7/1/2024, 7:31:27 PM.858 KNXUltimate-config: payload cache set to /data/knxultimatestorage/knxpersistvalues
                            [info] 7/1/2024, 7:31:27 PM.859 KNXUltimate-config: Autoconnection: yes Node KNX Gateway
                            1 Jul 19:31:27 - [info] Started flows
                            [info] 7/1/2024, 7:31:31 PM.865 KNXUltimate-config: Bind KNX Bus to interface (Auto). Node KNX Gateway
                            [info] 7/1/2024, 7:31:31 PM.870 knxUltimate-config: perform websocket connection on KNX Gateway
                            [info] 7/1/2024, 7:31:31 PM.870 KNXUltimate-config: Connecting... KNX Gateway
                            [info] 7/1/2024, 7:31:31 PM.871 knxUltimate-config: Connected to {
                            physAddr: '15.15.22',
                            connectionKeepAliveTimeout: 60,
                            ipAddr: '224.0.23.12',
                            ipPort: 3671,
                            hostProtocol: 'Multicast',
                            isSecureKNXEnabled: false,
                            suppress_ack_ldatareq: false,
                            loglevel: 'error',
                            localEchoInTunneling: true,
                            localIPAddress: '172.17.0.4',
                            interface: '',
                            jKNXSecureKeyring: null,
                            localSocketAddress: undefined
                            [warn] 7/1/2024, 7:31:37 PM.872 KNXUltimate-config: unable to read peristent file /data/knxultimatestorage/knxpersistvalues/knxpersist58ee8ce971302b69.json ENOENT: no such file or directory, open '/data/knxultimatestorage/knxpersistvalues/knxpersist58ee8ce971302b69.json'
                            [info] 7/1/2024, 7:31:37 PM.872 KNXUltimate-config: Loaded saved GA values 0
                            [info] 7/1/2024, 7:31:37 PM.873 KNXUltimate-config: Do DoInitialReadFromKNXBusOrFile
                            [info] 7/1/2024, 7:31:43 PM.969 HTTP getting resource from HUE bridge : Hue Bridge
                            [info] 7/1/2024, 7:31:44 PM.38 Total HUE resources count : 43​
                              Hi
                              Total HUE resources count : 43​​
                              This row at the end, states that the node found 43 hue devices.
                              You should see the lights showing up while typing in the HUE device field. What happens when you start typing? Any error whatsoever?
