- √ - Linknx-Installation scheitert an pthsem
    leider klappt die Installation von Linknx nicht so einfach, wie im Wiki beschrieben - bei ./configure (als root) meldet mir debian 4.0r2 (auf VIA-Epia Board) folgendes
    fe-knx:/home/frank/linknx-0.0.1.23# ./configure
    checking for a BSD-compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    checking for g++... g++
    checking for C++ compiler default output file name... a.out
    checking whether the C++ compiler works... yes
    checking whether we are cross compiling... no
    checking for suffix of executables...
    checking for suffix of object files... o
    checking whether we are using the GNU C++ compiler... yes
    checking whether g++ accepts -g... yes
    checking for style of include used by make... GNU
    checking dependency style of g++... gcc3
    checking for gcc... gcc
    checking whether we are using the GNU C compiler... yes
    checking whether gcc accepts -g... yes
    checking for gcc option to accept ISO C89... none needed
    checking dependency style of gcc... gcc3
    checking for ranlib... ranlib
    checking how to run the C preprocessor... gcc -E
    checking for GNU Pth... *FAILED*
    | Unable to locate pthsem in any system-wide location (see $PATH).
    | Please specify the correct path to either a pthsem installation tree
    | (use --with-pth=DIR if you used --prefix=DIR for installing pthsem in
    | the past) or to a pthsem source tree (use --with-pth=DIR if DIR is a
    | path to a pthsem-X.Y.Z/ directory; but make sure the package is already
    | built, i.e., the "configure; make" step was already performed there).
    Und das, obwohl ich vorher eibd sauber installieren konnte und auch funktioniert. Soweit ich weis, wird dort doch schon pthsem eingerichtet. Warum findet linknx die jetzt nicht?
    locate pthsem ergibt:
    fe-knx:/home/frank/linknx-0.0.1.23# locate pthsem
    /usr/lib/libpthsem.so.20
    /usr/lib/libpthsem.so.20.0.27
    /usr/share/doc/pthsem
    /usr/share/doc/pthsem/changelog.Debian.gz
    /usr/share/doc/pthsem/changelog.gz
    /usr/share/doc/pthsem/copyright
    /var/cache/apt/archives/pthsem_2.0.7_i386.deb
    /var/lib/dpkg/info/pthsem.list
    /var/lib/dpkg/info/pthsem.md5sums
    /var/lib/dpkg/info/pthsem.postinst
    /var/lib/dpkg/info/pthsem.postrm
    /var/lib/dpkg/info/pthsem.shlibs
    So wie es aussieht gibt es also kein DIR-Tree, so wie in der Fehlermeldung angegeben. Habe es so versucht ./configure --with-pth=/usr/lib - leider auch kein Erfolg.
    Wie komme ich da weiter?
    Frank
    Um etwas mit pthsem zu kompilieren, musst du auch pthsem-dev_2.0.7_i386.deb Pakete einrichten. Dieses Pakete enthalt die ".h" (header files), die erförderlich für kompilieren sind.
    Gruss,
    Jean-François
      Vielen Dank! Das hat geholfen.
