E-Mode and Ctrl-Mode
    Hi All,
    I have a few questions i hope you can help.
    KNX standart says that there are,
    S-mode (system mode for full configuration like with ETS)
    E-mode (Easy-mode for small installations limited configuration)
    And a controller for e-mode is also possible.
    But i was not able to find any KNX products with E-mode configuration option. Also i was not able to find any controllers for easy mode.Do you know any products or example installations. (is anyone using it)
    And also for S-mode knx standart is not saying that ETS is mandotary but i was not able to find any HMI solutions that are capable of configuring the network.
    What if a HMI user wants to change severeal group addresses (add/remove/change) are they always using ETS.
    Thanks
    Zitat von msan Beitrag anzeigen
    1. But i was not able to find any KNX products with E-mode configuration...
    2. What if a HMI user wants to change severeal group addresses (add/remove/change) are they always using ETS.
    Hi
    1. Nor was me
    2. Looks like
    Grüsse Bodo
      Hello..
      have a look over here:
      http://www.knx.org/fileadmin/downloa...0Eng_KnxRf.pdf
      and an project example for E-Mode Controller Mode:
      http://www.knx.org/fileadmin/downloa...g_Stars_EN.pdf
      Siemens uses for KNX-RF the push button mode,
      the configurator from Hager uses the features of the controller mode.
      PS: HMI-Users (Endusers) do not change alot of RF-Group-Addresses (Communication).
      You'r Welcome
      Peter
