Problem with Griesser MGX-9
    KNX/EIB Problem with Griesser MGX-9
    Hello,
    I have two problems with Griesser MGX-9. One is that I do see only "Einstellungen" and "Sperrfunktion" sections.
    Is this normal?
    Edit: The second problem seams to be more general so I removed it from here.
    Answers in German are ok, I'm just not good at writing it.
    Kris
    Well, who could have thought about this... anyway the solution is here Wie die Binäreingänge am Griesser MGX 9 belegen??? - KNX-Professionals Deutschland e.V. Forum
    Open properties window and then click on the icon of that window (in the upper left corner) and choose Options from there. Then select anything else than Standard.
    Problem solved.
    Help to control the lights with MGX-9 inputs can be found here https://knx-user-forum.de/knx-eib-fo...r-mgx-9-a.html
    Kris
