Problems with HS 4.12
    HS/FS Problems with HS 4.12
    Hi everyone.
    I decided to update my Gira Homeserver firmware (I had an old version).
    First, I am sorry if this was already answered elsewhere but my searches and limited german knowledge didn't find anything.
    So, everything went fine with the update except for 2 things:
    1 - I've lost the 1024x768 resolution in QuadClient. I've read here that since some newer version that design was removed. Is it so? Is there any way I can manually add it? I've tried fooling the QC xlm file into using design 1 (1024x768) but it throws an error that the design was not found. I know I can use the 1366x768 but it shows everything stretched. Was anyone able to restore 1024x768 resolution?
    2 - I was trying to use the UPnP Media renderer plugin of the QC but as soon as something starts playing....QClient crashes with a number error. The Media Server UPnP plugin shows the music library fine (I've tried TwonkyServer and Logitech Media Server) but the client crashes. I've tried playing on the internal QC Player or other UPnP player....both crashes. Any idea? I see that there is a 'Universal Player' plugin fully customizable. Can anyone show me a logic node example?
    Thanks.
    Regards,
    Mike
    I contacted the UPnP plugins author who kindly replied me.
    Apparently there is no way to make the plugin work in recent Windows versions and there won't be any updates of the plugin. I'll try using the Universal Player together with Volumio.
    As for the 1024x768 resolution....any ideas?
    Thanks.
      1024x768 is removed.....not good, but real...
